Question about Canon Cameras
I have a powershot a620. The battery compartment is coming undone...where you hold it..so the batteries have a little jiggle room. When it first "popped out" a small amount it was fine. on a recent trip it started coming apart more and the batteries then quit holding a charge. A fresh set of batteries now lasts about 20 min. I am guessing it might be because they don't have as good of a connection but I cannot get that part of the camera to go back under the "lip" and am afraid to take it apart w/o knowing for sure what to do.
  • equinaholic Oct 07, 2009
    It's not the battery compartment door. That still closes and latches fine. It is the whole part you hold in your hand. Imagine holding the camera and the fatter battery compartment is in your right hand. Now imagine your hand opening wider as that WHOLE compartment comes apart! :o/ The picture button is right on top and the part I am talking about fits under the 'lip' at the top where the button is and it has popped out from under that 'lip' when my son dropped it awhile back. Recently it started coming out more and I have to squeeze with my hand to hold it together better. The batteries are not having an up/down connection problem. More like a side/side problem where they come out from under the tabs because as the camera side opens they move to the side.
    Does that explain it better? I need to get the little tabs tucked back under the lip so that side of the camera is not coming apart but don't know where or how to get it done and I don't want to ruin it. It still takes pics, it just eats batteries.
  • Canon Master
  • 13,433 Answers
The battery contacts inside the camera, you can pull them up or towards your carefully so that they reach further.
Then close the cover properly and use some tape to hold it closed.
this will keep the batteries with a constant good contact, but I suspect the issue is probably not the batteries, try a higher capasity rechargeable batteries, something to the direction of 2000 or 2500 or more mAh.
I think its very unlikely that a poor contact would be draining the batteries, the mainboard of the camera is probably leaking or draining more energy than when it was new, comes down to poor quality components, things are not made to last these days, just a few years tops, in the intrest of profits...
Posted on Oct 07, 2009
  • Ekse Oct 07, 2009
    the plastic clips are most likely broken off, you would have to glue it together or replace the whole casing of the camera. you could probably buy a used or faulty camera of the same model with the case intact and replace it. Or glue it together.
Missing a screw on LCD screen.
Is this possibly the screw you need? If not, have you tried contacting Canon online or by phone to see if you can get the screw directly from them?
http://www.ebay.com/sch/i.html?_sacat=0&rt=nc&_nkw=Canon+A620+camera+screw
Nov 20, 2012 | Canon PowerShot A620 Digital Camera
I have a Sony SLV-N 500 VCR. The remote control very often does not work unless I remove the batteries and re insert them or jiggle the batteries. Is there a permanent fix?
It could be just bad soldering to the joints where the batteries connect. Also check no battery has leaked into the compartment.
May 05, 2011 | Sony SLV-N500 VHS VCR
Canon powershot a620 shutter won't open. installed new batteries and get the green light when turned on but lense won't extend.
You need to clean the contacts inside the battery compartment. Do this with a Q-Tip swab dampened in rubbing alcohol. It would be good to clean the battery and the charger also. Thank you,Dana
Sep 29, 2009 | Canon PowerShot A620 Digital Camera
My Powershot A620 will not power up from batteries (newly recharged and new Duracell alkaline)- I have applied a transformer to the external power input and voila all works fine - Any ideas welcome please.
If it's working using the external power input, then it's likely a problem with either the batteries, or the battery terminals (they may need cleaned or "bent up" a little to make better connection).
Here are some simple things to try for a camera that won't power on. They won't work for every case, but they're worth a try.
Aug 20, 2009 | Canon PowerShot A620 Digital Camera
A620 wont operate from batteries but will work off of ac adapter
Try replacing the batteries and check again. If this fails to solve the problem, try cleaning the battery terminals and the camera's contact points with an eraser. It could also be possible that the battery chamber's door is not closing properly. Try to press it while you turn the camera on.
Feb 04, 2009 | Canon PowerShot A620 Digital Camera
Cannon A620 won't work
I cannot access my 'Date Stamp' Function. the display is dark on the screen any sugesstions.
Sep 13, 2008 | Canon PowerShot A620 Digital Camera
Shuts off
I had the same problem. I figured out that it was being caused by loose batteries. When I would shake the camera, I could hear the batteries jiggle around and the camera would turn off. I fixed the issue by taking a stiff piece of wire; bending a little 90 degree hook on the end, and then using the hook to gently lift the little spring in the battery compartment. Now the batteries are firmly secured, and I don't have the problem any more.
May 20, 2008 | Canon PowerShot A640 Digital Camera
Powershot A620 Zoom Lever
Remove your batteries and look inside the battery compartment. Notice that there should be three small phillips screws at the bottom of the compartment. Tighten up all of these screws.
May 12, 2008 | Canon PowerShot A620 Digital Camera
Help??
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If the above didn't work, then consider the following:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 15, 2008 | Canon PowerShot A620 Digital Camera
Cameras Logo
26 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
