Are you sure you have a wire card installed? If so, then try this:
Right-click the My Computer icon and select Properties.
Click the Hardware tab and press the Device Manager button. The network card should appear under Network Adapters. Note:
If the card has a exclamation mark over a yellow background, then this
is an indication that the card is experiencing a problem. Go to Driver
download step 5.
Verify that the radio is enabled. It is possible to disable the transmitter of the wireless card without Device Manager showing any problems. Note: Follow the instructions provided to enable wireless card.
Most
wireless cards will put an icon in the system tray (the line of icons
in the lower right corner of your screen). Right click this icon and it
may have a menu option to enable/turn on the wireless radio.
Some
systems come with a Wireless Radio switch to disable the wireless
radios. The wireless radio switch is usually located on the front side
of the machine. If you are having difficulties with wireless
connections, make sure the Wireless Radio switch is set in the On
position.
Check for association to an Access Point.
If you double-click the previously mentioned system tray icon, the
configuration utility of the wireless card will appear. This utility
will be able to show the status of the wireless card, showing what
channel the card is using and what signal strength is being received.
It may be difficult to maintain a connection if signal strength is low
due to either interference or distance. For example, interference can
be caused by 2.4GHz cordless phones, other Access Points in the area,
and physical structures such as load bearing walls or metal partitions.
Note:
The utility can be used to configure the wireless card settings, but if
using Windows XP Zero Configuration or Access Connections, you will
need to use those programs to actually configure the wireless card as
they will overwrite the setting of the utility.
Thank you for your post. It was easy if I could find webcam settings, and flip it around as you say...
(More)
Thank you for your post. It was easy if I could find webcam settings, and flip it around as you say but I cant, neither could a technician. Any ideas where to find it? Thanks.
I have a HP PSC 1510 ALL IN ONE. EVERYTIME I TURN ON THE PRINTER IT MAKES AN ALIGNMENT COPY. hOW CAN...
(More)
I have a HP PSC 1510 ALL IN ONE. EVERYTIME I TURN ON THE PRINTER IT MAKES AN ALIGNMENT COPY. hOW CAN i STOP THIS WASTE?
labtop acer aspire saya LCDnya terkena air. bagaimana cara menghikangkan air yang berada dalam LCD...
(More)
labtop acer aspire saya LCDnya terkena air. bagaimana cara menghikangkan air yang berada dalam LCD tersebut.
My Acer travelmate 2492wlmi wont detect or play DVD's/CD's anymore. Even when I go into My Computer...
(More)
My Acer travelmate 2492wlmi wont detect or play DVD's/CD's anymore. Even when I go into My Computer the drive (E) does not appear at all. Any suggestions/remedies would be greatly appreciated? Regards
