the door would not open. An engineer showed us how to use the emergency release catch at the bottom for the time being and ordered a new lock. On going to fit the lock the engineer said it is not the lock but the circuit board !! seemed to suggest that somehow water had got onto it, but cannot see how. Have you any ideas as to what is wrong??
My OKO Lavamat 61300 has stopped rotating (and spinning). Fills and drains OK and seems to step...
(More)
My OKO Lavamat 61300 has stopped rotating (and spinning). Fills and drains OK and seems to step through programme OK - just doesn't turn.. Is there a fuse I can check? Is it likely to be the motor itself? or could it be the starting capacitor? how can I check? thanks
The Machine runs the clean water from underneath. The pipe connection is good. (AEG Lavamat 72640...
(More)
The Machine runs the clean water from underneath. The pipe connection is good. (AEG Lavamat 72640 Update Front Load Washer)
