Question about Gateway Televison & Video
My Gateway GTW-L13M103 13" monitor/TV tuner has momentary good picture upon powering on, then only brief flash of picture as I change channels, but essentially a black screeen while operating. Audio is fine. Is there a fix I can do without much problem? This is a 2003 model that I got for free with a computer so I don't want to spend much $$$ on it.
skotkolr
  • 558 Answers
SOURCE: lcd tv
blown capacitors on the inverter/ vga board
Posted on Apr 27, 2008
  • 3 Answers
SOURCE: Gateway plasma tv
I had the same problem outline by other posters here:
- no image on screen
- no control by remote
- ocassional flashing of screen back-light (while still no image)
- amber led when rear "master switch" engaged, then green led when powered "on" with remote power button or front panel power button, but still no image
- could not power off with remote power button or front panel power button (had to use rear "master switch")
And, as noted by at least two others below, found the same cause/culprit: a pin and connector on the power board pictured by Mike (posted Oct 11) was discolored and apparently over-heated. Whether this was the cause or effect, I don't know, but the end result was separation of solder on the rear of the pin and poor contact between the pin, connector and ultimately applied power.
As Mike posted Oct. 11 and bitzzy posted Nov. 22, the solution is to fix the bad connection. After removing the power board I re-soldered the weak pin connection and also removed the corresponding connector on the cable connector to clean and check the connection. After reassembling, I am happy to say everything is back to working perfectly!
Thanks to the internet and kind posters on this forum for helping me find the problem and fix it without dropping $hundreds$ for a repair or a $thousand$ for a new set!
Posted on Jan 10, 2009
  • 537 Answers
SOURCE: NO PICTURE ON MY 42 IN PLASMA TV GTW-P42M102
http://shop.adc-ast.com/cgi/display.cgi?item_num=DPWB11396-1G-T http://shop.adc-ast.com/cgi/display.cgi?item_num=DPWB11393-1G-L http://shop.adc-ast.com/cgi/display.cgi?item_num=PDP42WVSN3S
Posted on Jun 11, 2009
milkburp
  • 416 Answers
SOURCE: no sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Posted on Mar 26, 2010
ahmosea
  • 47 Answers
SOURCE: 1. momentary sound, then no sound no picture; 2.
Hi, if the power indicator flashes 4x blue more then likely its a SDR buffer logic board. When you take the back cover off they are the long boards on the left side of the tv. There are 2 boards. If you look closely at the black chips on the boards which there should be 8 on each. If you see a burn mark or a deep scratch mark then the chip is fried. If you take the lower one of and turn the tv on it might come on and if not try the top one. Please rate me and let me know how you do.
Posted on Jul 29, 2010
HD Tuner
The Gateway GTW-P42M303 can display HD content. However, you will need a set-top box to get that content. The TV only has an analog tuner (NTSC or PAL, depending on the area where you purchased the TV). Thus, you will need to connect a digital-to-analog converter to get most over-the-air stations. (Only low power stations are still broadcasting in analog.) Most of the common d-t-a converters only provided SD (480i) output. There are some HD tuner boxes available; you may have a hard time finding them.
If you have cable or satellite service, then you can get the HD programming package and view it on this TV.
I wish that I had better news for you.
Apr 26, 2013 | Gateway GTW-P42M303 42 in. Plasma...
I picked up a gateway GTW-P24m303 for free from a friend. The unit powers on, but I just get the occasional flash of static, nothing more. The capacitors look good, but I don't have the equipment to...
The main tv Tuner signal board it the causes and the problems,it have ICS and some components are short in the circuits somewhere.Try website like Ebay.com to a whole refurbish main Tuner signal board for the replacement.This problems could be any components parts and ICS dies on the main tv Tuner signal board,best just replaced the whole board because tries to troubleshoot,u have to know alot of electronic theories and components functions to repair it.
Jun 07, 2011 | Gateway GTW-P42M303 42 in. Plasma...
A brief history: fixya helped me change my bulb (been receiving a "replace bulb" message for awhile until my picture went black). The picture now is snow, not black which seems to me to indicate the bulb...
Since you do have sound but snow for picture is your TV 54J or 54U chassis the PT50DL54J chassis shows 4 tuners also Have you look for Leaky or Bad capacitors if they are puffed up on top they are Bad 2200uf 25v 1000uf 25v Look for bad capacitors on tuner Boards, and I have seen where they are on Power supply board that will affect Picture.
Dec 04, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Jun 11, 2009 | Gateway GTW-P42M102 Television
Digital Signal?
This TV does not have a digital tuner built in, so you'll need a converter box if you want to get off-the-air digital broadcasts. These boxes are available at all big retailers and on-line. The US Gov't is offering $40 coupons to help pay for these, but the program is out of money and all you can do is go on a waiting list at this time. Information is at www.dtv2009.gov.
Feb 05, 2009 | Gateway GTW-P42M303 42 in. Plasma...
Gateway plasma tv
I was able to resolder the pin shown in the picture and it fixed my problem as well.  I also used a razor and cut off the last socket for that pin on the connector and put a dedicated connector on so that it will take the heat a little better.  Also when I re-soldered that pin on the bottom side of the board I scraped away some of the protective coating around the solder puddle so that I could make a bigger solder puddle to add a little more strength and heat resistance.
Dec 26, 2007 | Gateway GTW-P42M303 42 in. Plasma...
Televison & Video Logo
212 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
