Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Invalid drive message
Hi Shayna
When installing software to drives D,E, F, I get an invalid disk message.running xp pro 200 gig hard drive divided into c; d; e; f; loading to c: drive is ok. robert
  • 20 Answers
Try this solution:
Invalid drive
Posted on Jan 06, 2009
  • 70 Answers
You will have to reformat the hard drive. You have probably suffered a filesystem crash. you can recover the data by using a recovery application like recover my files
Posted on Dec 24, 2007
I made a mistake installing my new WD 500 PATA drive. I need to remove the DDO because I can't see more than 131 Gigs of the drive. I'm using XP Pro and my MoBo bios will see the full 500 gigs....
If you have XP installed on this drive and it is functioning correctly it would be best to use a third party software to resize the C drive or create an additional partition with the free space that you are not seeing. Installing an application like Acronis Disk Director or Partition Magic will give you much more flexability on your storage space.
This is a freeware software link below for EASEUS Partition Manager.
http://www.partition-tool.com/
Jun 11, 2011 | Computers & Internet
Mecer wont load wi xp sp2 on 160gig hardrive
The BIOS is seeing the drive but your computer can only see about 120-130 GB of harddrive. If the drive has a pin option to limit it's size you may be able to limit it then install windows but if it doesn't you're back to looking for a smaller drive.
Hope this helps
Chris
Aug 17, 2009 | Computers & Internet
Emachine t5026 boots only with os disk in drive
Emachines don't use the cable select properties very well. Change your drive to Master, reformat and reinstall the operatiing system.
Apr 10, 2009 | E-Machines (T2958) PC Desktop
Full Hard drive
you can merge to partitions on a single disk, although this should be one of your last resorts. when two partitions are created on a single drive the OS recognizes the two partitions as two seperate drives. From win xp pro, you can access all the data on the partition with xp home platform. the second partition will take up close to a gig of space that could be used. the simplest way would be to creat shortcuts to the programs you want in the partition for xp pro. then right click my computer> properties> advanced> start up and recovery settings> select win xp as the default OS and deselect the box marked "time to display operating systems"
this will stop that annoying 30 sec pause that you get when you start your computer asking which OS you want to run.
or if you seriously want to merge the two, here is a link with a download that will help.....download this file and creat an disk to insert into the disk drive and restart to load from the disk
http://download2.lsoft.net/BootDiskDemo-Setup.exe
the only thing is that if you write over or delete files that those programs need to run smoothly, you will have to reinstall them completely. in which case you would be just as well off to back up your info and do a clean install. i trust you will be able to determin which solution is best for you needs.
Personally if i had programs i wanted to save, i would take the first option and just have two partitions
Mar 11, 2009 | Dell Computers & Internet
Downgrade from Vista to WinXP Pro
No, you need to go into your computer's BIOS and set the ahcp mode to IDE. Then windows xp will see it just fine.
Please take a moment to rate as fixya. Thanks!
Feb 06, 2009 | Acer Extensa 4620 Notebook
160 gig sata hard drive that keeps on failing
hello what brand is ur hard drive. western digital has software that can scan ur hard drive for possible hard ware errors, as does seagate. in addition ur motherboard may have a test that may help (smart something not sure but good luck)
Jan 24, 2009 | Abit : AL8-V LGA775/945P/FSB1066/ATX...
Wrong Hard Drive Capacity
Any hard drive larger than 130GB have to be installed using Windows XP SP2. Windows disks, Pre SP2, will not recognize the large hard drive on 130gb of drive.
Jan 12, 2009 | Compaq (166361-001) Motherboard
New sata 500 gig hdd - ST3500320AS SD15
Dear Customer,
thats problem regardiong to your windows version if its working proerly when newly installed than may some files delted during some uninstalation can do all this stuff,
so try to install new full version windows xp than try ,i m sure about that your problem will fixed up.
THNX
May 17, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Logitech quickcam chat v11.1 software install problem
Try this link and download version 11.5 onto your hard drive, by installing from hard drive the invalid drive should be bypassed.
Install the software before attaching web cam.
Mar 24, 2008 | Logitech QuickCam Chat Personal Web Camera
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
250 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
