Question about Minolta Office Equipment & Supplies
I am getting a C004A error on a Minolta 4000 copier.
Is there an error reset on the Minolta 4000 also ? If not, does that mean I have to get another fan installed ?
  • Minolta Master
  • 1,297 Answers
Optical section fan motor failure.Change the fan motor.To reset open and close the front door or press the service reset button(placed in the left up side).
Posted on Oct 08, 2009
ERROR CODE C0040 ON MINOLTA 4000
Suction fan motor fault. Check all vents also check all fans!
Nov 29, 2013 | Minolta Office Equipment & Supplies
Minolta 4000 c520 error
Open the front door then look to you upper left. See a small access cover remove one screw the press the trouble reset button. Machine must be on. If the code come back do not reset you are resetting codes for the fuser the hot part. it could catch on fire and that would ruin a perfectly good day! Have the fuse looked at if the code comes back before resetting the code
Aug 07, 2013 | Minolta EP4000/5000 CS/PRO Copier
What is Error C0110 for ep 4000/5000 cs pro
Could not find that code in the service manual how about C0000 or c-0010
Apr 18, 2012 | Minolta Office Equipment & Supplies
Have a MINOLTA CSPRO 4000, erro code C0040----"FAN
The fan is not easy to replace...... The fan is located under the black transport belts. The fan is part
of the unit that brings the paper from the transfer & drum to the fuser unit. The unit is black and it looks like tank tracks. From what I remember the fan is acturely in the transport unit ... Good Luck
Apr 27, 2011 | Minolta EP4000/5000 CS/PRO Copier
I have a Minolta CSPro 4000, and I am getting the following errors on the display screen code 0d50
C0d50 means you have a duplex error. This would be coming from the duplex drawer just under the main front door. You must open then close the duplex drawer to reset this code. It can not be reset by opening/closing the front door as with most other codes. Most of the time the c0d50 code will reset by opening/closing the duplex drawer. If not you will need service on the drawer as there is a drive or sensor problem in the drawer. The guides in this drawer have to jog in and out for different paper sizes and orientations. This code is usually causes by a failure of the guides to move properly.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 29, 2010 | Minolta EP4000/5000 CS/PRO Copier
Minolta CSPro 4000 with error code C:C0040
Fan motor, open close front door, to reset.
Oct 28, 2010 | Minolta EP4000/5000 CS/PRO Copier
C 0040
C0040 is a cooling fan failure code. Opening and closing the front door wil reset the code. Doing this while "bumping" the machine will restore the machine to operational MOST of the time. Cooling fan replacement will eventually be required. Resetting though can be accomplished in most cases.
The part number for the fan is 9313-1310-61 and here is a picture of the fan which is located behind the rear cover.
Jun 12, 2010 | Minolta EP4000/5000 CS/PRO Copier
Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
Jan 07, 2009 | Minolta EP4000/5000 CS/PRO Copier
Service
it means it time for the cleaning web, and waste toner bottle to be replaced. once you replace it you can reset the indicator.
thanx,
mikey
Mar 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
167 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
