Question about Lucent PARTNER18 Corded Phone
Guest mailboxes will not answer
Guest mailboxes that are setup just ring, and will not go to voice mail. This happens from the auto attendant, and from a call being transferred to a guest extension.
    President:
  • Lucent Master
  • 860 Answers
Programming on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
Enter #301
The display will say Automatic VMS Cover Extension:
Enter in the extension number of the phone that has the guest mailbox
The display should say 1 Assigned, if not press 1
press feature "00" to logout
Posted on Oct 07, 2009
Even though my answering machine indicates it is on, noone can leave a message.The response is that the mailbox has not been set up.Can you help? Thank you.I have had this system for quite a while and have...
A "mailbox not set up" message is coming from your telephone line voice mail system, and not from your telephone answeringmachine. What this means is that the voice mail on the phone line is picking up before the answering machine has a chance, and since the mailbox hasn't been set up it can't take any messages. So there are two things you'll need to do.
First, you'll need to set up your voice mail. You may need to contact your telephone service provider for setup instructions since not all systems are the same, but here's how it usually works. From your home phone, call your own number so you reach your voice mail. You should get the message that your mailbox hasn't been set up, and will be prompted for an access code to get to the setup menu. The access code is usually the last four digits of your phone number, and you'll be prompted to change it to something else as part of the setup. Through the setup main menu you can record your greeting and set up other options like the ring count before the voice mail answers. Set it for a number larger than the setting on your telephone answering machine. (I have my answering machine set to 4 rings, and voicemail set to 6.)
Step two is to verify the ring setting on your answering machine. Four rings is a common default setting, but it's adjustable on the phone. Most newer phones have menus that you access from the handset to set change settings, while older models have a switch on the base unit.
Once the mailbox is set up and you have your answering machine set to pick up first, everything will work as you want.
Aug 14, 2011 | Uniden DECT 6.0 Cordless Phone
I have a Panasonic 6.0 DECT Talking ID Caller phone system. I lost my message that callers hear when the answering machine answers the phone. Somehow my granddaughter's voice has been recored and that...
Making Use of the Voice Mail Service
From your own extension
VPS* Extension No.
Mailbox
· If you have no password, you can skip the last step.
* VPS: Voice Processing System
From someone else's extension
VPS Extension No.
Mailbox No.
Mailbox Password*1 +
Listening to a Message
Password*1
KX-TVA series
Listen to Message
Deliver Message
Mailbox Management
Automated Attendant
Message Notification
Other Features
End Call
KX-TVS series
Listen to Message
Deliver Message
Check Mailbox Distribution
Automated Attendant
Mailbox Management
Other Features
End Call
VPS Extension No.
Leaving a Message
Mailbox No.
Enter the desired mailbox no.
To send the message immediately
Leave a message
(KX-TVA series)
(KX-TVS series)
Follow the guidance
To set the delivery time
May 24, 2011 | Cell Phones
We have a Landmark/Southwestern Bell Telecom DKS 308/616 system and need to know how to access and change the auto attendant greeting.
Call your own number or press and hold #1 button and when the message starts playing press either # or * and follow the directions. It's usually #
Apr 16, 2010 | Cell Phones
CP100 Auto Attendant transfers direct to voicemail
The norstar extension may be setup up for Call Fwd to voicemail, or call fwd/busy. Also, Custom Call Routing may be setup to send the caller directly to the mailbox.
Nov 10, 2009 | NorStar CallPilot 100 Voice Mail, 10 mail...
Are there both a night menue and a day menue for partner pc mail
On the smaller flash card type voice mails no. On the larger voice mails yes.The option would be under auto attendants (3) in the system administrators mailbox.
Sep 22, 2009 | Avaya AT&T Partner Phone
Calls routed to Mailbox message
Your autoattendant is programmed to be started on line one instead of all lines. If this is helpful, please post as such. Ask for details if needed
Mar 26, 2009 | Vodavi Starplus SP7314-08 Corded Phone
Panasonic 816 reduce from 4 to 1 ring before auto attendant ans.
You can voice mail to answer after one ring.
You will need a programmer to program ringing.
info@ameritelnj.com
Tony
Dec 02, 2008 | Toshiba DKT-2020 Corded Phone
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Remote Access
When you call in from the outside wait for auto attendant to answer. As soon as the "Thank you for calling" starts, press [*], and your mailbox number. If that does not work you may need to put a [#], 165 before the [*], mail box. This is assuming that most voice mail and auto attendant settings are operational and you have a Panasonic KX-TVS voice mail.
If a live person (not to be confused with the living dead) answers, have them transfer you to voice mail and do the whole [#], 165, [*], your mail box thing.
Dec 05, 2007 | Panasonic KX-T7453 Corded Phone
Lucent PARTNER18 Corded Phone Logo
103 people viewed this question
Top Lucent Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
tfelton3
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
