Question about LaCie Computers & Internet
500 gb external drive won't boot to my iMac. Orange light on drive comes on but never goes to yellow. Never shows up on desktop. Tried different USB ports and computers.
    Problem Solver:
  • 5 Answers
There should be a special USB wire that is available for portable hard drives. Basically it might just need power in which the The USB cable has two inputs so one is used for data transfer and the other for power.
Posted on Oct 07, 2009
How do you boot from an external hard drive
When you power up the Mac hold down the alt/option key. after a few moment you will get a different start-up screen. It will show your internal HD and then when the curasoe comes back it will also show you any external drives with valid start-up software on them.
Eorks with DVDs and CDs and other macc connected by Firewire in target disk mode.
Mar 23, 2012 | Apple iMac G5 Desktop
Rocstor external harddrive disappears from desktop. Why?
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Mar 05, 2012 | Rocstor Storage Rocstor Rocpro 225 500 GB...
Rocstor icon disappears from desktop and light is half orange/green
hope this helps you
Imac is not detecting my LaCie External Hard Drive
Do you have a CD disc software installer of your external hard drive (F.A. Porshe 160GB).? If you got it, you must reinstall it, so that your Imac can detect it. Otherwise, find it at the internet and download it.
The power failure could have damage some stored data about your External Hard Drive in your Imac. That's why, you have to reinstall it. Send us your e-mail comments for us.
Oct 17, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
I have exactly the same problem!
check hdd on different system or change the bus cable then check , if the problem persists then its the problem of hdd
Sep 14, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Simpletech 500 GB external hard drive - unresponsive
If you really can not get it to work anymore, you could try opening it up and connecting the hdd directly on a IDE/SATA port in your computer. This will only work if you have a desktop, for a laptop you would need all kinds of converters.
May 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
LaCie 500 GB hard Drive - does not register on my desktop
if it is a USB (or you have low disc space), it does take longer to show up on desktop and patience is required... on my iBook it takes over a minute for my Brick to show up... Whether it is USB or firewire, do try another cord (I had similar problem with my lacie firewire external... I used a different firewire cord and all was fine. If you have tried these already, I hope you find the answer... good luck
Jun 07, 2007 | LaCie (300951U) 500 GB Hard Drive
Power light blinking orange/yellow. does not mount or recognise
IN SPANISH...USE TRADUCTOR OR TRANSLATE.... TRATA DE USAR UN SOFTWARE LLAMADO PARTITION MAGIC DESDE LA SE?AL C: O SEA BAJO DOS.... PERO ANTES CONTESTAME TU BOOT O SOFTWARE DE INICIO RECONOCE EL DISCO DURO?... SI NO LO HACE O ES UNA DA?O LOGICO O SEA DE LA TARJETA DEL DISCO DURO, O FISICO, DEL DISCO EN SI, LO CUAL EXPLICARIA EL RUIDO.... HAY EN INTERNET SOFTWARE FREE.... PARA DIAGNOSTICO Y HASTA REPARACION... UNO DE LOS MEJORES SE LLAMA HIREN´S BOOT CD Y SE BAJA COMO UN ISO Y LUEGO LO GRABAS EN UN CD LUEGO HACES BOOT CON EL Y CORRES EL SOFTWARE QUE QUIERAS, INCLUYENDO EL PARTITION MAGIC, ESPERO QUE TENGAS SUERTE. SI PUEDO SERTE DE MAS AYUDA TENDRIAS QUE SER UN POCO MAS ESPECIFICO. HAY OTRO SOFTWARE BAJO LINUX LLAMADO KANOPPIX Y EL EN OCASIONES RECONOCE LO QUE OTROS SISTEMAS OPERATIVOS NO HACEN.... ASI POR LO MENOS RECUPERARIAS TU INFORMACION Y SI ESTAS DE BUENAS LO FORMATEAS DE NUEVO Y RECUPERAS TU DISCO. ESTE TAMBIEN LO CONSIGUES EN INTERNET Y ES FREE.
Jan 14, 2007 | LaCie (300728U) 250 GB Hard Drive
Computers & Internet Logo
187 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
