CD and DVD Burners
Problem for CD and DVD Burners
Generic problem for all CD and DVD Burners
JVC DR-MV77SU DVD/VHS recorder will not dis...
By wyattearp61 on Dec 24, 2007
I have 2 sat. boxes and a RCA RT2280 1500 watt dolby surround sound all hooked up and the final out to the tv comes from the out to tv on the surround sound box.
I have the 2 sat's with the out to TV going into a 2 in and 1 out coaxial switch becausse the are coaxial the out on it hooks into the in for Sat. on the JVC player recorder under sat. inbut I need to set the tv to channel 3. The sat's work show up on the tv and are ok with video and sound. But I can't get into the setup menu to setup ths jvc DVD recorder. Do I need to be on a aux channel on the JVC box to see the menu ? and if so how do I get into it. I tried the TV aux but no good just snow, Any one know how I can get the JVC setup screen to show on my tv to be able toset it up with this configuration.
Thanks
Woody In Alabama
Comments:
Dec 24, 2007
- The RCA plugs go to the output on Sat. box and connect to input on the JVC recorder, I also have a optical line run between the sat. and JVC recorder.
Dec 24, 2007
- out put goes into surround sound amp....then out to TV.
Dec 25, 2007
- Figured it out I used a RF Modulator and hooked it up to sat. boxes (using a coaxal 2 in - 1 out switch) connect to input (coaxal) at modulator and the out at the modulator coaxal to the in TV. Hooked the RCA plugs Red, White, Yellow up to DVD/VCR(out to tv) and at modulator connect RCA jacks to in put from DVD/VCR. worked like a charm.
I googled how to connect a new DVD/VCR with no coaxial connections by coaxial to a tv.......and found the answer: By using a RF Modulator box.
Put in in your onboard computer (brain) and save it.
Woody Steppe
Best Solution
posted on Dec 24, 2007
Very Helpful)
otacon
Rank: Guru
Rating: 89%, 1894 votes
To what is the JVC player connected to?
Comments:
Dec 24, 2007
- Ok, so the Sat box outputs video to the JVC via RCA and audio via an optical cable. How is the JVC connected to the TV?
Dec 25, 2007
- I am glad it worked out for you =)
Rating Locked! (?) wyattearp61 has rated this solution as Very Helpful
Popular Solutions for CD and DVD Burners
Questions and Unsolved Problems for CD and DVD Burners
Answer
I need an internal cd/dvd burner drive tray where to buy one
Answer
Hi my name is kerrie.. I am looking for a gz-mg26 burner. CU-VD10 SHARE STATION.Apacer AD330 DVD... (More)
Answer
NO matter what blu ray player I use my LG ggw-h20 blu ray drive won't play Blu ray movies. I have an... (More)
Answer
No matter what blu ray player I use (cineplayer w/update, powerdvd,or Total Media Theatre) my LG... (More)
Answer
nec nd-3550a will burn to some blank cds but not to others from the same package. when some blank... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For CD and DVD Burners:
Top CD and DVD Burner Experts
Rank: Guru Guru
Solutions: 14880
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more CD and DVD Burner Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
