Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
Insinkerator running but water is not franing?
Insinkeraror running but water is not draning?
  • 115 Answers
Try stuffing ice in disposal and then turning on this clears lodged food and sharpens blades
Posted on Dec 04, 2009
Our super old insinkerator is spewing out water and gross dirt junk! What do I do?
It has to be clogged, try putting some Very hot water down the insinkerator. Remember if you have a dishwasher, it also usually uses the insikerator to drain. The Ice wont hurt the unit... so try both.
Jun 19, 2014 | In-Sink-Erator 1019E InSinkerator Batch...
Tip
How to get your washer to work when it does not spin or drane
go to the fillter at the front of the mashine and turn it to open, make sure mashine is turned off.put a bowl or plenty of towels down let the water drane out then clean the filter out.put it back in close it and away you go
on Feb 16, 2010 | Washing Machines
Insinkerator instant hot water faucet
Insinkerator stainless tank does not have anode rod to protect from rusting. So these water heaters rust out at welds. And must be replaced. And this is frequent problem.
Copy following link for installing under-counter water heater and see manuals for various models available. Non-insinkerator water heaters have anode rod to protect from rusting:
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 23, 2013 | Water Heaters
My badger insinkerator only drains will the unit is running
Clean out the drain and see if that helps.
Remove both nuts on p-trap and trap falls loose.
Remove tailpiece from side of disposal.
Hang rag over disposal opening so it directs water downward.
Run water and turn on disposal.
Turn off disposal and use coat hanger to remove debris if necessary.
I wrote disposal replacement steps that include tips for reattaching tubular drain pipes:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Aug 15, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator leaks water from the bottom. this is when water runs through. no difference if the unit is running or not
There is no repair, just replace the unit. Once they start leaking, that is fatal. you could not repair for less than replacement of the unit.
Jan 21, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Why is there running alot of hot water in the drane line ? Why is the cycle to long ?
There will be two water lines. The line on the left is the hot water line. .... Examples of water heating systems often low on dissolved oxygen are long standby periods, ... After contact time has been allowed, drain chlorine solution in tank ... Flush all chlorine from piping by running hot water faucets until no ...
Aug 10, 2010 | Refrigerators
Insinkerator badger 5 runs sink wont drain
Properly piped, your arrangment should look similar to this picture so that there is a separate trap for the disposal and the other sink basin.
Mar 05, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
How to replace heating element for InSinkErator W154 water heater
take the front cover off, it is just snaped on, there you will see it, depending on the age of the unit insinkerator will replace it for free, you just have to install it, but for the most part it might be cheaper to change the unit
May 12, 2009 | Emerson InSinkErator W154 Water Heater
Insinkerator hot water heater takes a long time to dispense water
It may have mineral deposit buildup on the inside. You will need to consult your maintenance manual to see how to flush the unit and clear it of deposits. You can also contact Insinkerator for the information as well. You can use vinegar to clean it just like you would a coffee pot. Take the inlet supply off and using a funnel pour the vinegar in and turn the unit on.
Apr 03, 2009 | Emerson InSinkErator C1300 Chrome...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
199 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
