Circuit board on AC unit at home was replaced, turned on unit and new circuit board burned also burned spots at the same locations as older board? What could be the problems?
    Guru:
  • 587 Answers
You have something in that circuit that's pulling high amps or shorted. You need to determine what is in that circuit fan, compressor, contactor, wiring, etc and fix it first.
Until you fix that you will keep burning up boards.
Posted on Oct 08, 2009
I have a Mitsubishi TV model WD-65C9 and yesterday I heard a pop sound and the screen went black but there is still sound. Is this just a lamp bulb issue?
That pop noise was a so called "CAP" capacitor letting (they actually blow up) go on a circuit board, open the TV cabinet up and look carefully for a burned spot on the circuit boards, it will be small, when you locate that board it may fix the TV is you replace the damaged board.
Mar 23, 2017 | Mitsubishi Televison & Video
Hi :) I have the Trane Furnace that just turn on
on older tranes if 120v power is reversed it would do that try switching leads on pigtail to board. make sure to unplug first!
Oct 31, 2013 | American Standard Trane Ge Gas Furnace...
I had a fire in the microwave and now it doesn't turn on. Is there a reset button or do I have to go buy a new one? cbierke@gmail.com
It sounds like an internal fuse has blown. Unplug unit and carefully open the top cover to provide access to the A.C. power cord entry point. Hopefully the fuse is located in that area and is the older style 1/2" long glass or ceramic body with metal endcap on each end. ONLY REPLACE WITH A FUSE THAT HAS IDENTICAL ELECTRICAL RATINGS! After replacing the fuse and top cover reconnect the unit to the A.C. outlet and check to see if it is still dead. Still dead = repair shop time.
NOTE: Use a "fused" A.C. outlet strip (usually 6 outlets with circuit breaker) for your "after fuse replaced" testing. This gives you additional protection against accidentally tripping a breaker in your homes electrical panel.
Oct 19, 2010 | Maytag Microwave Ovens
I have a whirlpool side by side refrigerator model no GS5SHAXNB00 refrigerator light blew this morning i replaced the bulb no lights working on refrigerator side and temp control settings
you need to replace the main/board for sure located in the lower rear left hand wall of the unit in a plastic case, it will have 3 wire harnesses unplug the unit,undo the plastic container and unplug the the board and there will be a burned spot on the case and burned trace on the circuit board, reason being,this is very common on any of these sideXsides,if a light blows out in the refrige compartment it puts a surge on the board and burns the circuit trace open,this makes the digital temp read-out go dark and if the lamps light at all they "strobe" dimly or not at all,and you will hear a clicking of the relays in the rear area trying to latch the light bulb circuitry, but cant because the main/mother-board is defective now
Mar 02, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Loud ticking noise when i close freezer and lights on icemaker flash like a stobe light. fridge and freezer wont hold temp. ice amker and water dispenser dont work?
if your lights burned out recently and the digital temp read-out is now dark also,burned out lights will cause a power surge and will destroy the main-board circuit trace(mother-board), it is located in the back side of the refrigerator, in a small plastic case,when you remove it you will see a burned spot on the circuit board and the loud clicking sound is a relay on the board trying to latch to light the bulbs and operate the unit
Feb 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
When the refrigerator is turned on, the compressor does not start and there is a clicking of a relay on the mother board.I have replaced the condensor fan motor as it was froze up, and now when the relay...
replace the mother board,if recently lights burned out in the unit and on some the digital read-out is also dark,the motherboard got a power surge and is defective,its in the rear side of the unit and will have a burned spot on the circuit trace,another tell-tale sign of this is if the new light bulbs are strobing and will not light fully
Feb 20, 2010 | Refrigerators
COMBINATION OF PROBLEMS WITH MODEL 25 HOT POINT SIDE BY SIDE. UNPLUGGED IN FREEZER FAN SO REFRIDEGERATION UNIT WORKS AND TOOK OUT ICE/WATER CHUTE LIGHT SO WATER INDOOR DISPENSER WORKS. LOOKED AT CIRCUIT...
i think you answered your problem / sounds like the board. some times you can smell the burn and some boards have clicking sound . / from what you have stated . i would replace board. mm the burn is the price of the board .. mm
Dec 03, 2009 | Dryers
I tuched the remote control ,then unit turned off ,the leds started blinking.the unit was running normaly just before
If this is a ac unit,a window unit,then the control circuit board has burned out,a lot of times the fan motor will cause this to happen,I just wish they never would have went to circuits in ac units,because of this,circuit boards just don`t go with moister to well,and they can`t hold loads either.If this was helpful,please let us know,thank you.
Nov 16, 2009 | Heating & Cooling
Burn out circuit board
hi! there! replace the burn out circiut board,what ever you pull out the same thing you put back just be sure that has the same model and specification,calibrate and test overload protection,defective overload protection replaced to prevent any burn out,short circuited mostly came to burn those thing that's why imposing preventive maintenace schedule for this kind of large ac central unit is very much significant.mostly timer delay circuit malfunction on large scale unit supplying by three phase a/c source on central control panel board.when ever replacement occured try to put mark or list color coding of specific terminals to connect and isolate short circuit make possible to detect at once before installing the new one and make make record on this for future reference we have several cases like that after buying a new one and replaced still burn again,the common cases is that they did not find the cause of short circuit connection they just relay on circuit board burn out,so it better to make assured that every thing is fine before installing the new one.specially on supply source of circuit.,relay on diagram and manuals take and check all data source as reference this will be a great help.take all necessary precaution this should be done by qualified technical ac support,have a nice day and regards
Mar 31, 2009 | Heating & Cooling
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
474 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
