I have a miller hvac unit model number PCZD-030KB it appears due to filter being too full. I have solved that problem and understand that i now need to hit a reset button. Can anyone tell me where it is on that model? It was part of the house when i bought it so no manual.
  • 89 Answers
See if there is a small red button close to the refrigerant line on the outdoor unit. If so puch the red button in and unit should start
Posted on Oct 08, 2009
How many filters does my unit have
If the A/C is in your furnace then your furnace filter takes care of filtration.
Jul 30, 2014 | Intertherm Heating & Cooling
WHERE CAN I PURCHASE A CHEAP NEW OR RECONDITIONED COMPRESSOR FOR MY ICE MACHINE? tIMES ARE HARD AND I CANNOT AFFORD THE $600 FOR A NEW ONE.
Hello Smokinjoex5,
I need to know a model number of the unit in question. The model number should be located on the rear of the unit and/or the numbers off of the compressor. You do understand that you will still need to have a service tech come and install the compressor as this is not something that you can do, you have to be a licensed HVAC service tech.
Post back and I will try and locate you a compressor.
Thank you for choosing FixYa.com
Justin
Apr 19, 2011 | Ice-O-Matic IceOMatic IceOMatic 400 Lbs 38...
Washing machine model zwf14070w1. Machine is flooding from underneath, drum is making loud grinding noise when rotating, and filter is full of what appears to be white synthetic fibrous material, which we...
Noisy machine is due to improper or fault in the drive of the motor and agitator assembly . You might have to remove this unit and overhaul , maybe the bearings or hub need a change.
Also try to use some lubricating oil on the moving shaft so as to lubricate and reduce the noise.
The filter clogging is the fiber that comes from the clothes while it is tumbled and in a period of time will accumulate. you need to clean them occasionally.
the flooding is due to clogging of filter of the drain and resulting in leaks . Check the drain pump/valve, check the hose fittings and make sure these are tight. check the inlet pipelines for leak and the washer door gaskets.
Feb 23, 2011 | Zanussi Washing Machines
Going to replace hvac system. Don't know what
According to the model number it is a 2 ton or 24,000 BTU unit. It is very important that you change the indoor coil as well as the outdoor section, due to it being a 10 SEER unit, and the new basic systems are 13 SEER, the old coil cannot handle the higher SEER ratings.
Rheem and Ruud are the same equipment, just 1 number different on the model number.
I hope this has helped, please rate the new guy :)
Please contact me if I can be of any further help to you.
Have a great day!
Sincerely,
Paul Gibson
Apr 04, 2010 | Ruud Matching Split Air Conditioner
I need help locating the reset button for an old Miller HVAC (heat pump) - i had one of those micro-filters in and the compressor shut off - my A/C repairman friend told me the reset is now what I need to...
I don't believe " Miller" brand has a manual reset for high pressure. The disconnect box on the wall next to the out door unit is fused. It has a pull bar in it and has the fuses attached or behind it, depending on the box. The fuses are " slow blow " fuses, a little more expensive than normal, but if one is bad, change them both. Only check them with the breaker turned off. If you cannot check them it would be worth while replacing them. Chances are that is your problem. Most of the time that is all that is wrong, but there is a chance that something wrong in the electrical for the outdoor, ie capacitor, compressor or fan motor, in which case you need a service tech to make that call.
Oct 09, 2009 | Heating & Cooling
A latch on my microwave door is broken. Do I need to get the entire door or can I get the piece?
It depends on the brand and model number.
You can find helpful exploded view diagrams and order parts for many brands by entering your full model number here.
FixYa is currently not notifying us when my Clarification Requests are answered, so please contact me directly with your full model number from the tag on / in the unit so we can help you with free do-it-yourself tips and/or an estimate.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 06, 2009 | Microwave Ovens
How do you change the charcoal filter on the GE Profile spacemaker 2.0
You can download GE owner's manuals and installation instructions here.
You will need the
full model number from the tag on / in the unit.
You can find helpful exploded view diagrams and order parts (such as a charcoal filter) by entering your full model number from the tag on the oven
here.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more help.
William E. Miller
prototech@usa.net
Sep 08, 2009 | GE Profile Spacemaker Over-the-Range...
Buzzing noise.microwave not working
That's almost always a defective filter capacitor on the control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
May 19, 2009 | GE JVM1860 Microwave Oven
Whirlpool Velos Microwave showing "Error F7 HV SMPS Feedback" error. What does that mean?
F7 means that the control panel is not getting feedback from the Switched Mode Power Supply (high-voltage inverter).
This could be due to a problem with the inverter or the control unit / circuit board, but it appears to be the latter in most cases.
We repair microwave control boards for customers nationwide with our guaranteed $39.95 service.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful.
You may reply back with your brand and model number if you'd like us to look into this further, or feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
prototech@usa.net
Jun 26, 2008 | Whirlpool Microwave Ovens
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
