Question about Dell Latitude D800 Notebook
My cd-rom will not open. What should I do?
I have removed it entirely from the computer and put it back in. The computer recognized it being removed and being returned.
I disabled and then enabled in device manager.
there is no light on and it doesn't respond to the button being pushed or selecting 'eject' from my computer.
What should I do?
  • 3 Answers
It sounds like the drive spring is bad. There's usually a small hole on the drive itself, you can stretch out a paper clip and stick the paper clip in the hole to see if it will release. If it releases, the drive's not picking up on the power being delivered by the system. See if you can swap it with another drive.
Posted on Oct 07, 2009
I have a cd I put in, but do not know how to remove it from my computer need help
1. Open the Computer window on your PC: Either double-click the Computer icon on the desktop, or open the Start menu and choose Computer.
2. Click the DVD drive icon: Clicking the icon selects that drive.
3. Right click on it and choose 'Eject' from the drop-down list.
OR
Try the following only if the above steps didn't work or in times of urgency, such as when the computer is locked up (or turned off), you can manually eject a disc/cd by pushing a straightened paper clip into the tiny hole (the "beauty mark") on the front of the DVD drive.
f90a6593-7fec-4205-a633-379cc4b71e53.jpg8572a8b8-67cd-4c33-bbf8-d5d51bfdd48d.jpg8681c4da-0608-43dc-b4b8-cee760b38e11.jpg
Nov 28, 2013 | Computers & Internet
Can't get into any folder because c:Windows/System 32/rundll32 .exe keep popin up
To resolve this issue, follow these steps:
1.
Put the Windows XP CD ROM disk in the CD ROM drive.
2.
Click Start , and then click Run .
3.
Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4.
Restart the computer
2.
3.
4.
1) Put the Windows XP CD ROM disk in the CD ROM drive.
2) Click Start , and then click Run .
3) Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4) Restart the computer.
Oct 27, 2010 | Computers & Internet
How do I open the tower to insert a c d
Open My Computer and then right click on the CD/DVD drive of your system that are define. For example: "E, or F, or G". Click on eject. or Press on the button CD/DVD-ROM. Mostly it's located in the right sight just below the CD/DVD-ROM "where the CD/DVD can insert". And if this two is not working than take a pin length around 2.5" and push inside the hole it's located in the right sight just below the CD/DVD-ROM. Hope it'll be helpful to you. All the Best!
Oct 07, 2010 | E-Machines eMachines Desktop PC
My cd-rom drive keeps on opnening and closing?can you help me? i remove the IDE cable but it still opens and close...TNX
Dude CD ROM's are designed to close all by themselves in case if there is anything stuck in between,just unplug the CD Rom,and u might find a small hole,kindly punch in it using a pin so that the front portion of cd rom will open and clean up the entire drive using a soft brush(b careful about lens present inside)and fix it back and check out whether it works out
Nov 10, 2009 | LG CED 8120B CD-RW Burner
How to instal a laptop dvd rw
open cd rom tray.open laptop lcd screen flat, remove the 2 screens on the back of the hinges.carefully remove the bezel(just above the keyboard, with the power buttons etc )from right to left.remove 2 screws securing keyboard.you will see one screw that holds the cd/dvd rom in place.remove screw,pul on tray carefully, cd rom will slide out. replace with new cd rom.
Dec 07, 2007 | Acer Aspire 5100-5033 Notebook
Cd-rom/dvd-rom door won't open
Hi!This is not a big problem...All you have do is take a pin, needle or something and just insert it into the small hole near your cd-rom drive..try this repeatedly while pressing the eject button..If it doesn't work you will have to unscrew the two screws on the right of your keyboard..doing this will give you the access to the cd tray and you can remove the cd and put it back together..
Nov 13, 2007 | Averatec 3200 Notebook
My cd-rom
Hi, You should be able to get a paper clip, preferably one of the bigger ones and open it out so you have a straight section of wire, then at the fron of the CD drive you will find a very small hole. Carefully slip the wire into the hole as far as it will go then you will need to push against the manual release with reasonable pressure and the door will come open. Remove your disk and close the door and restart the machine. It may be that the disc became stuck for some reason and froze the drive. Once the offending disc is removed it will hopefully come back online.
If it doesn't come back then the CD drive may have failed, fortunately they are not too expensive to replace anymore.
Oct 29, 2007 | E-Machines emachines (emachinees) CD-ROM...
Cd rom drive is stuck closed, done everything i can think of to get open, don't want to break anything, pls. help, thanx, deige.
Quasi every cd rom had a little hole for emergency eject,you can put a paper clip on it for opening the lock when the computer is off. Also under the laptop must be a screw which take the cd-rom on place.Removing only this screw you can remove entire cd-rom drive by pulling it out. You can do this with laptop turned off and the battery removed. Never use excessive force.. Hope this can help - Bye
Sep 04, 2007 | HP Compaq Presario V2000 Notebook
Dvd-r/cd-rom automatically ejects
My Dvd-r/cd-rom automatically ejects. Please help!
Justis
Feb 07, 2007 | Dell (Y4081) CD-RW/DVD-ROM (Combo) Burner
Dell Latitude D800 Notebook Logo
60 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
