Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Got an error 4 message on a edw 9213I electra didhwasher
Didhwasher taking longer up to 3 hr to complete regular wash
John: According to AcmeHowTo.com: When the cycle time is too long, "
  • Test the timer motor
  • Test the heating element
  • Test the thermostat"
  • May 21, 2015 | Dishwashers
    E1 error on kenwood didhwasher
    Gday
    As you said, it is not getting water.
    E1 is just the machine telling you this.
    A couple of easy ones to check:
    1. remove the hose where it screws on to the dishwasher, leave the other end connected to the tap (preferably put the machine end in the sink or a bucket as to not make a mess), and turn on the tap. If the water is not getting through the hose, it may have a faulty water block (flood preventer) on it.
    2. If there is water getting through the hose, make sure that the hose is not kinking as you push the dishwasher back in to its hole.
    3. If there is water getting through the hose and it is not kinked, and you cannot hear any water going into the machine, you may have a faulty inlet solenoid or control board. Might be cheaper to get someone in to fix it. If you were to guess, I would start with the solenoid, as it would be the far cheaper part.
    4. If you do hear water rushing in before you get the E1, then the machine does not know that it is getting water. Could be either a faulty pressure switch or the pressure tube that goes to the switch.
    Hope this helps
    Adam
    May 04, 2013 | Dishwashers
    How do I remove switch housing on dyson dc18?
    I have a similar problem and want to check the switches...the last release is not apparent...appreciate some help...edw@nebulax.cm
    Oct 09, 2012 | Dyson DC18 all floors Bagless Upright...
    My voicemail has been set up, but it will not answer calls.. it rings and then rolls back into the main message for the office
    Set your Call Forward Busy/No Answer to go to voice mail ext. as follows: Lift the handset, dial 4 then 3 followed by the voice mail ext. (the number you dial to retrieve voicemail messages). Hang up.
    Jul 26, 2011 | NEC Electra Elite 32D-1 Corded Phone
    Hi I actually have an EDW 1477 washer/ dryer. I keep getting an E20 message, the machine then beeps and stops! Any idea what the error is and what I should do? Thanks
    This is a problem associated with the drum not emptying water - usually a blocked empty pump filter. Electrolux have an excellent support site. Go to:
    http://electrolux.co.uk/en-gb/Support/Troubleshooter/?Command=Detail&CategoryId=98&SymptomId=1412&DetailId=1412
    and click on START ANIMATION for a walkthrough of what you need to do
    Jun 23, 2011 | Electrolux EW1000i Front Load Washer
    Not draining completely
    check the drain spigot under the sink it may be partially blocked. After that check the sump of the didhwasher for blockages. After that the pump must be checked. you may need help for that good luck
    Sep 05, 2010 | Dishwashers
    Solution for Thermado DW245ub dishwasher
    You don't have enough hot water coming into the didhwasher. The element is coming on to heat the water. Are you using the sanitizing cycle? Vitally
    May 13, 2009 | Thermador DWU244 Dishwasher
    How to change time on NEC Electra Elite IPK? I
    You have to be on the root phone or "first phone".
    To check various phones -Hit {feature} 4.
    Should display 100= TEL 01. Once on the first phone then use {feature} 9 #.
    Time will flash at top of display and can be adjusted.
    If you are not on the first phone you will get error at the top of the display. Leave the hand set on the hook.
    Mar 11, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
    Edw 8020 remote code
    I lost my remote somewhere , so I went out and brought another remote But I dont have the codes to make it work on my centrios DVD recorder can your help me THANK - YOU
    Nov 27, 2007 | Centrios EDW8020 DVD Recorder
    Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
    75 people viewed this question
    Top Hotpoint Dishwashers Experts
    Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
