Question about HP G60-230US Notebook
Lightscribe drive My DVD/CD Drive is not working, i cant see it whenever i open to view drives
  • 3 Answers
Go into the BIOS of the system to make sure it sees the drive, if not there is an issue either with the drive itself or the controller on the board. Try pressing the eject button when the system is on to see if the drive is receiving power, if not, the motherboard has a defect more than likely
Posted on Oct 07, 2009
HOW DO I DOWN LOAD DRIVERS FOR A LIGHT SCRIBE DVD WRITE ABLE /CD RW DRIVE. MODEL # GSA-H3OL
Hi...
If your LG LightScribe drive will not need drivers to work as a 'normal' DVD drive as this function is Plug n' Play.
BTW - You have a great drive there... I have GSA E10L and a GSA E40L - Both fantastic drives...
However to use LightScribe you will need both:
1: LightScribe System Software
and
2: LightScribe Labeling Software.
You can download the System Software here:
http://lightscribesoftware.org/lightscribesystemsoftware/
And FREE LightScribe Labelng Software here:
http://lightscribesoftware.org/freesoftware/windows/
Happy Scribing...
Steve
Sep 29, 2015 | Computers & Internet
Lightscribe dvd drive won't work. the eject command does not make it open either. seems to be jammed. if i break it down can it be "unjammed" without ruining it?
Actually it's probaly just got some dust or something in it. What you do to manually open it is take a needle, thumb tack, or safety pin and simply insert it into the tiny hole above the eject button on the dvd drive itself. You'll feel the tip of the button when you push the pin into the hole then it will pop the door and the drive will open properly. This has gone on for cd/dvd drives for years. Usually just the cause of dust or what have you being stuck in the mechanism.
Jul 01, 2013 | Computers & Internet
I would like to install a lightscribe drive , can it be put into the hot swop carrier space witch i don't use
Yes you can add the lightscribe drive to your system as long as you have an open pay (slot) to hold it. If you have a desktop tower, then most likely you have a slot available either right under or above the current dvd/cd drive.
Just make sure your lightscribe drive has the same interface (SATA or IDE) as your current drive or you might need some cable adapters to make it work.
If your system uses IDE (little metal prongs or pins where the cable plugs into the back of the dvd/cd drive) then you want to set the jumper pin on the back of the dvd drive to CS for cable select. If there is a cable ribbon going to the current drive it will have another connection open that you can use for the new drive. Normally the cable ribbon will allow you to piggy back the two drives.
SATA is the latest technology so if your current drive is SATA, and your lightscribe is SATA then look at the two cables that go into the dvd drive already installed. There might be another set that is not being used that you can hook to the lightscribe drive. If so, hook the set to the back of the drive and into the slots on the motherboard.
May 18, 2012 | Acer Aspire M3400 PC Desktop
Im having trouble with my drives it wont read the cd or burn the cd or dvd
Hello there,
If your LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe does not read disc, burn cds or dvd, then it means there is a problem with the lens of the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe.
You will have to replace the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe or have the lens replaced.
Be sure not to use the LG SecurDisc 20x Internal Double-Layer DVD RW/CD-RW Super Multi Drive w/LightScribe to watch movies as that weakens the lens easily.
Hope this helped.
Goodluck
Elect_Comp
Aug 09, 2011 | LG SecurDisc 20x Internal Double-Layer DVD...
Hi there, my Lg drive works but the lightscribe driver is not recognized. How do i get the Lightscribe to work on Windows 7? thank you
once connected to your computer windows seven should automatically detect and install it
there may'be a problem with power or a registry issue
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps you
Jul 24, 2011 | LG GH22LS50 22X SATA LightScribe DVD+RW...
I can't print label to cd dvd from my dvd unit
Before you can use a lightscribe facility, you must have 3 things, which are, A DVD Drive thats has a lightscribe capability/function, a lightscribe software, and a lightscribe compatible CDDisk.
From what I can see, your drive is not capable, or does not support lightscribe functionality. I tried to check everything about your system model and I discovered that the capability of your DVD Drive is this :
  • Writable DVD formats: DVD-R (6x, DL [double layer]), DVD-RW (6x), DVD+R (DL [double layer]), DVD-RAM
  • CD formats: CD-R (24x), CD-RW (16x)
Which means your DVD Drive does not support Lightscribe facilities.
You can also check everything about your system from this link :
http://gdgt.com/toshiba/satellite/a305-s6857/specs/
Hope this helps you out.
Jul 13, 2009 | Computers & Internet
Cant get lightscribe to work does not see my dvd burner as a lightscibe burner
  1. Clean Drive: w. commercial cd/dvd cleaner + air compressed can with narrow pipe inserted into device to reach lens.
  2. Update your sw from http://www.lightscribe.com/ (Control panel, diagnostic tool, application)
  3. be sure service is started: as Administrator go to Control panel/Administrative tools/Services
    double-click on Lightscribe Service, and if it says disabled change it to automatic, then "start service" in the left pane if is already started and set to automatic stop and restart it you don't have to reboot to see results.
It worked for me on HP6710b with internal drive and with liteon external burner
Jan 01, 2009 | Lite On LITE-ON DVDRW 20X8X8X 20X6X8X 12X...
PC didnt detect the lightscribe function
  1. Clean Drive: commercial cd/dvd cleaner + air compressed can with narrow pipe inserted into device to reach lens.
  2. Update you sw from http://www.lightscribe.com/ (Control panel, diagnostic tool, application)
    double-click on Lightscribe Service, and if it says disabled change it to automatic, then "start service" in the left panel. If is already started and set to automatic stop and restart it you don't have to reboot to see results.
Dec 29, 2008 | Pioneer DVR 105 DVD-RW Burner
System cannot see lightscribe drive
try to update the firmware of that drive. then try to go to device manager to see if there are any changes.
Mar 23, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
HP G60-230US Notebook Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
