Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
My Sony KP-53HS30 rear projection tv looks like a 3d movie without the glasses. It comes and goes and sometimes will have red, green, blue squigley lines all over the picture
  • Sony Master
  • 3,459 Answers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
My Sony KP-53HS30 rear projection tv looks like a - 3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 15, 2010
  • Edward
    Edward Apr 23, 2011
    Glad it worked
Sony kp-51 ws500 rear projection tv. when turn on tv there is 3 duplicate images overlayed...green, white, red. looks like I am watching an old school 3d movie, but without the glasses. i already took the...
The problem is your convergence circuit board gone bad. This is commonly caused by shorted/open IC on that board. First try to spot if there is a bad solder joints and resolder it. If nothing replaced the convergence IC. Also check the resistors around.
Hope it may help you.
Have a nice day!
Thanks for using Fixya.
Feb 13, 2011 | Sony Televison & Video
Picture red and blue shadowing
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 04, 2010 | Sony KP-53HS30 53" Rear Projection...
Kp-53HS30, red blue green are not focused, seems like a 3D images..pictures is bright clear with slight curves verticly, turn on great..is this a convergence problem? are ther chips that can be replaced?...
Its nice to save money but unless you know what you are doing and have the right soldering equipment its best to leave this to a pro. you can open your tv and inside there are two large ics labeled STK 392-xxx those are where the problem is , however with sony tvs there are fuses that need to be replaced and possibly some resistors,. have a tv shop repair your tv. Julio - Millenium TV in Las Vegas
Dec 30, 2009 | Sony KP-53HS30 53" Rear Projection...
Double images red blue green lines
My picture screen has double images red,blue,green. The screen looks 3D
Dec 28, 2009 | Sony KP-53HS30 53" Rear Projection...
Connecting the laptop VGA output to my Sony-KP-53HS30
There are products such as VideoSecu PC to TV Presentation Converter. I haven't used them. I'm not sure you are going to get the resolution that you want. A DLP projector does a pretty good job. I know that is not what you are looking for.
Type "PC to TV Converter" in Google. They are about $40 to $60 bucks. Before you buy one, read the reviews.
Dec 27, 2008 | Sony KP-53HS30 53" Rear Projection...
Looks like watching 3D movie(colors) and rounded
convergence IC.s replacement and realigment job for expert technician no to expensive job
Apr 07, 2008 | Sony KP-53HS30 53" Rear Projection...
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Red green and blue lines
Most projection TVs have an option to refocus. For example, my Sony rear projection TV has a button on the front for focusing the lamps. Try finding this button or option in the menus with your remote. Projection TVs actually use three lamps, one red, one green and one blue. These need to line up exactly in order to form a good picture, and when they come out of focus, you see the edges which sometimes has the effect of a 3D image when you aren't wearing 3D glasses. Hope this helps!
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Colors are not in line together, 3D look
hi, You most probaly have a problem with your convergence, goe into menu locate convegence try and adjust and see if there will be any changes, if not i sugest it be done by a profesional. zazwpx
May 29, 2007 | Sony KP-53HS30 53" Rear Projection...
Picture Distortion
you have a convergence problem.. If you understand how this works then you can go into the set find the convergence ic's and replace them and sometimes you need to do some alighnment as well. Its always best though to let a service tech do a job like this as he will have all the proper equipment to adjust and troubleshoot the set Good luck
Mar 30, 2006 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
228 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
