Question about Pro-Fit Pro.Fit Ns 50 00 Infiniti I30 /I35 & Nissan Maxima 00 Up
I30 cigarette lighter is not working. Where is lighter fuse located?
Why doesn't my cigarette lighter work? Is it a blown fuse? Which fuse do I replace for lighter?
Your owners manual shows you location and number and an illustration of the box you can also google the image
Oct 27, 2015 | 1989 Mazda 626
Where is the cigarette lighter fuse located in a 97 buick century?
GOOGLE is your friend! Open up Google then search for this exact phrase (without the quotes)
"97 buick century cigarette lighter fuse location"
Aug 05, 2014 | TRUCKSPEC TSP-311 12-Volt 2 Outlet Fused...
Toyota sienna 2002 where is the fuse located for the Cigarette lighter?
cigarette lighter fuses are normally either located with all of the other fuses or up underneath the dash
Jul 06, 2012 | 2002 Toyota Sienna
Where to find fuse for cigrette lighter
Fuse number 18 20amp is for cigarette lighter.Its located in the trunk compartment fuse box. ------- If you need fuse box diagram showing the cigarette lighter fuse.Click the link below and see the diagram:---
http://technoanswers.blogspot.com/2011/10/where-is-cigarette-lighter-fuse-located.html ---------- This will help.Thanks.Helpmech.
Oct 10, 2011 | 1994 Cadillac DeVille
Fuse for the cigarette lighter in Infinity FX35
is the only thing not working the cigarette lighter? the fuse that operates it is usually the accessories fuse, it normally operates the interior light as well, which fuse box have you checked,there is most likely one under the bonnet & there also may be one under the dash as well, it might well be that the cigarette lighter element is the problem,try another lighter....hope this helps....cheers
Jul 06, 2010 | 2007 Infiniti FX35
Looking for cigarette lighter fuse location...
Look for the accessories fuse in the fuse panel. If the fuse is still good then you cigarette lighter is burnt out and will need to be replaced. Hope this will help you.
May 20, 2010 | Cars & Trucks
Need location of fuse box containing cigarette lighter fuse
On some vehicles the cigarette lighter fuse is attached to the cigarette lighter assembly itself. Check if you can gently prise the cigarette lighter assembly out of its location in the dashboard, or remove any panel that may allow access to the rear of the cigarette lighter and look for the fuse (it may be an in-line one in the power lead to the cigarette lighter or it may be physically attached to the cigarette lighter itself). Failing that, the fusebox is normally under the dashboard on the driver side, but some fuseboxes can be found under the dashboard on the passenger side. There should be a diagram under the fusebox cover that shows what circuits each fuse protects. If a fuse has blown ensure that another of the same type and value is used to replace it.
Dec 25, 2009 | 2004 Dodge Neon
The cigarette lighter isn't working
on a right hand drive s type the fuse for the cigarette lighter is under dash right hand side it is fuse no 32 20 amps
Apr 28, 2009 | 2000 Jaguar S-Type
Pro-Fit Pro.Fit Ns 50 00 Infiniti I30 /I35 & Nissan Maxima 00 Up Logo
341 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
steve morris
steve morris
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
