Question about Storage Controllers
Vista won't recognize usb hard drive
I am running Vista 64 bit and it won't install a driver for my usb hard drive or usb thumb drive. Shouldn't these devices be installed with the normal usb driver?
4 Suggested Answers
SOURCE: Installation of new hard drive
yes that is a driver issue, you need to install the motherboard cd, all those with question marks are not functioning well if you will install these drivers you will soon experiencing the slow down of your pc upon boot up and sometimes it will hang. since your motherboard is an asus you may download the drivers to asus if you don't have the motherboard cd
Posted on Dec 16, 2007
  • 30 Answers
SOURCE: problem installing external hard drive
Run device manager and keep it running during the installation of drivers. It will take a bunch of drivers, but it will work and it will stop once it has all the drivers installed.
Posted on Dec 29, 2008
SOURCE: System freeze
The issue was resolved by uninstalling SP3. I uninstalled SP3 and the USB PCI card and rebooted. When SP2 reinstalled the device it installed the corect driver (5.1.2600.2180) and everything is now functional. Have no idea why the correct driver was not in XP SP3.
Posted on Jan 25, 2009
  • 1288 Answers
SOURCE: Need driver for Windows 7
These can be found on Atto's site i believe, but you need to register to download the drivers
Posted on Dec 29, 2010
0 characters
1 Points
64 bit driver promise ultra
There is no official Window 7 driver for the Promise Technology Ultra 133 TX2, but you can use the Vista driver. It should also work for both the Ultra 66 and the Ultra 100 cards.
I found the Vista driver at:
The file name is: Ultra133 TX2 windows logo driver.rar
This file is compressed in the rar format. I decompressed it using 7-Zip. Folder amd64 contains the 64 bit driver. The amd64 driver worked even though my mother board has an Intel CPU and chip set.
Oct 31, 2013 | Promise Ultra100 ATA/100 Pci (ultra100 tx2...
Hi, I have a promise fasttrack 100 tx2 controller on windows seven 64 bit. But i can't find any drivers for 64 bits and it's not running.
you could try this although for xp its an update
SlimDrivers automatically updates PC drivers with real-time scanning and cloud technology. The first cloud-based utility for updating and maintaining drivers, SlimDrivers provides instant optimization of the interaction between a computer and its system components and periperhals, such as printers, graphic and sound cards, motherboards, USB ports, game controllers and other devices and hardware. SlimDrivers scans a PC, identifies the correct drivers needed, and retrieves them from the cloud, automatically installing the most current, precise drivers for each individual PC. SlimDrivers features a one-click, start scan button on its product homepage, which begins the process automatically to scan a PC and identify out-of-date or broken drivers. Then, seamlessly, SlimDrivers creates a personalized driver profile of that PC, and accesses the online cloud database for the most up-to-date, customized driver software.
hope this helps you
Sep 06, 2011 | Storage Controllers
I have transfered a LSI20160 SCSI card to my new 64-bit Windows 7 PC, but I cannot find a proper driver for the card.
I'm assuming its a driver issue.
The installation cannot proceed. Can the Vista Driver be used? Or do I need a Windows 7 specific SCSI driver?
If the Vista SCSI driver can be used how does one use the Vista driver with a "Clean" install?
Aug 06, 2011 | LSI Logic (LSI20160LP)
Need win 7 drivers for SD SIL680-Raid card
try the vista driver it should work ok
32 bit driver is here
64 bit driver is here
if you found this useful please vote for me
Apr 22, 2011 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
Wat driver do i need for the lpk25 to talk to windows 7 64 bit?
Feb 18, 2011 | Akai LPK25 Laptop Keyboard Controller (...
EASYCAP DC60 USB 2.0 Video Audio Capture Adapter. I bought one of these about one week ago and I have still not been able to capture any data from my TV, set-top box (and that is another story altogether!)...
The problem is the device is not compatable with a 64 bit system; only 32 bit. The advertising that it's Vista compatible is extremely misleading. See the Amazon site customer reviews of this product for a greater explanation. I suggest you return it if you can.
Oct 06, 2009 | Storage Controllers
Adaptec 29160n vista support issue
vista has a major issue with allowing even the admin to move and transfer files and folders.
I have run across a fix that helped me gain more control, but you probable need to get drivers for Vista from the scsi controler card manufacturer.
and for the drives.
Vista is a terribly restrictive OS.
WARNING: please do not do this if you can't reverse it on your own if needed. Editing your registry can be risky so use extreme caution.
if you follow this it helps.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Windows Vista Admin Hack
click start and run,
type in regedit
when Registry editor opens
click on HKEY Local Machine
click SYSTEM
in the area where there are values right click and select new/ DWORD
enter "EnableLinkedConnections"
press enter
right click EnableLinkedConnections and chose MODIFY and change the value to 1
Save and exit Registry Editor.
Jun 17, 2009 | Adaptec SCSI Card 29160N [ 1835000 ]...
My Seagate Free Agent Classic external hard drive won't work
Have you tried a different USB port? Some USB chipsets are prone to frying if you use the front accessible ports. Also, try the drive on another computer.
Jan 21, 2009 | Storage Controllers
Problem installing external hard drive
Dec 28, 2008 | Dell (073VDD) SCSI Controller
Computer doesn't see hd
hi, re: sabrent enclosure:
sort of same issues. documentation is feeble. hd powers up. red light is on.
but the new pc doesn't recognize the drive and, obvously doesn't assign a
drive letter to it.
i tried reversing the cable, changing the hard drive, using different usb port,
re-booting. still doesn't see the drive.
1. jumper settings are correct
2 i use vista, not win 2000 or xp
2 harddrive is old, from old computer
vista doesn't have 'my computer'
i can find manage disk management
can't right click becausse the drive isn't there
how do i change the hdd settings from dynamic to basic if i can't see the drive?
answers to your questions":
1. i'm running windows vista home
2 size of drive... it's old and probably fat(32) under 1g
3 i cycled through the settings
j8 jumper settings
slave, master, & single
no settings work
4. yes i heard the drive spin up
5 the led is red, not green
thx again for your efforts
ken bossewitch
Dec 03, 2007 | Sabrent (USB-2535) (USB2535) IDE...
Storage Controllers Logo
345 people viewed this question
Top Storage Controllers Experts
Brian Sullivan
Brian Sullivan
Robert Graf
Mike McWhinney
Are you a Storage Controller Expert? Answer questions, earn points and help others
