Question about Panasonic KX-TG1033S Cordless Phone
I actually have a KX-TG1031S 3 phone set. No dial
I actually have a KX-TG1031S 3 phone set purchased from Frys. No dial tone. Sounds dead when hit talk, but lights up correctly.Have checked all the connections and they seem correct. The light on each phone shows that they are charged.
sandiiii
  • 17 Answers
SOURCE: phone repair
the links tat r there inside the phone are shorted as they r very thin threads like..just go to a repairer and he will resoulder the links and the problem will be solved..for temporary work just open the phone and remove all dust ..mostly keypad will start working
Posted on Nov 24, 2007
  • 25 Answers
SOURCE: my KX-TG 8231B
Make sure the phone is pluggd into the wall properly. If so and no dial tone is detectable make sure you installed the batterys on the handsets correctly and that they are fully charged. If you have a friendly neighbor with a working phone line plug youre phone into their line and if it does not work and you followed my previous instructions seek a repair center in youre area that honors panasonic warranties. If the phone is pluggd in at the neighbors house and it works use it to call the phone company.
Posted on Mar 26, 2008
  • 22 Answers
SOURCE: panasonic KX-tg9333
There is an option on the phone you need to access to clear the voice mail call alert light.Check your user manual.
tk46
Posted on Jul 20, 2008
SOURCE: GE 25942 dial tone problems
After waiting for over 24 hrs for an answer from FixYa and then they wanted $10.00 and trying to fix it myself, I gave up. Threw all that c$$p into a box, took it back to the store and got my money back. It just wasn't worth the time and aggravation.
jadyn08
  • 12 Answers
SOURCE: Uniden cordless phone. No dial tone.
Hi peddler65, did you plug your phone into another area to see if there is a dial tone. Then if not call the phone company or find the D-mark (where your dial tone ) comes into your home and put a jack on that and plug a phone in with all phones in the house unplugged.
Thanks.
Posted on Nov 15, 2008
Our KX-T7735 phone system is not working, yet our phone service is live. Is there a code we need to unlock?
Have you tried pushing to CO button and then dialing out?? Otherwise unplug the phone from the wall and power, pull batteries and wait half hour and reconnect.
Nov 13, 2013 | Panasonic KX-T7735 Corded Phone
How do I program different ring tones for the KX T7220. THere are 6 to choose from I believe.
1 Press program key
2 Dial 99
3 Press line key or intercom key twice
4 Dial 1-8 for tone type
5 Phone will ring with new tone
6 Press store button(autodial)
7 Press program key to end
Dec 07, 2010 | Panasonic KX T7220 Corded Phone
My panasonic kx-tga431al has all of a sudden changed the dial tone. instead of the regular tone, it now has a tone that sounds like a busy signal... what do i do to fix this?
Have you set up 'Call Divert' which returns a 'Broken Dial Tone'
Dial #21# if it is on a Single Line Telephone, or if fitted on a Business System check programme for 'Call Forward'
Jun 30, 2010 | Lands Phones
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
No dial tone - I have to dial using the speaker phone
sounds as if this phone will need to paired with the base again.
May 30, 2009 | Panasonic KX-TG5632 Phone
No dial tone
Purchase another unexpensive phone. Check if you have dial tone. If not call your carrier.
Mar 18, 2009 | Panasonic KX-TG5632 Phone
It sounds like rotary dialing
I have a similar Panasonic phone (KX_TGA101S).  Someone must have inadvertently changed the dial mode on you.  Here is how you change it on mine, which should be similar to yours.  Hit the Menu button.  Scroll down to "Set tel line" and hit the Menu Button (OK). If it isn't displayed, scroll to "Set Dial Mode" and hit the Menu Button. Select Tone instead of Pulse and hit the Menu Button.  That should do it.
Jan 25, 2009 | Panasonic KX-TG1033S Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Dial tone
my phone has no dial tone and when you call the phone it has a busy signal. There is no static just sounds like it is not hung up.
Sep 23, 2008 | Panasonic KX-TG1033S Cordless Phone
Panasonic KX-TG1033S Cordless Phone Logo
119 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
