Question about Royal Vacuums
Hi. Bought a M3888-3 Royalcylinder vacuum from Lidl. Lost manual that came with it. Only had it 4 mths. Need new hose. Plastic hose has snapped near whereit attaches to metal hose. Can I get a replacement hose from somewhere in U.K.? I know the vacuum is from Germany.
fanny
  • 146 Answers
SOURCE: Kirby Belt Lifter Assembly
I have tried to get a parts breakdown for your vacuum cleaner with no success. The way that then washers should go is the flat smotth metal washer on the inside followed by the fibre washer and the wavy washer on the outside. The waves are used to bite into the plastic so it cannot work loose.
Posted on Nov 09, 2007
reddevil6
  • 1673 Answers
SOURCE: ELECTROLUX OLYMPIA ONE HOSE
Usually the older hose get replaced, they just weren't made to be repaired, if it looks like something that will come off, then try either warming the sleeve up with hot water or a hair drier to see if you can work it off after it has warmed up.
Posted on Apr 26, 2008
SOURCE: Numatic Henry Hoover
They should just pull out with a little pressure and a pair of pliers. Good luck with your repair
Posted on May 28, 2008
SOURCE: Fantom Canister Vacuum parts
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12055&thid=723654
Posted by jaybird73 on Jun 30, 2008
Hi, Don. I'm in need of a part for my Fantom Canister. It's a little difficult for me to describe but here goes...the part is the small metal "pins" that are found in the connection between the hose and the motorized floor attachment. There are normally 2 found in that area, they are about an inch long and I guess they pass the electricity between the hose and attachment. Any help is appreciated.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sound so me that it could be a lower wand with the pins in the end or the part of the power nozzle and the part that the lower wand fits into is called the gooseneck and that can be replaced as well. If it is part of the hose then you may have to replace the hose and that could be expensive or over $100.00 or more, as an estimate. The best place to get the information is the owner’s manual under trouble shooting or to cal the Fantom factory of which I will provide for you @ the bottom; or your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.fantom.com/ Customer Tech Support 1-800-798-7398
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 03, 2008
  • 107 Answers
SOURCE: Belt keeps snapping
Check your brush. It is likely that the brush is broken and will not spin. Hold the brush by the end caps and spin the brush and if it will not spin freely that is your issue.
Posted on Dec 18, 2008
I bought a new plastic end piece for the hose but can't get the old one off the hose to change it???
Soak the end of the hose it very hot water to soften the end of the hose. Then insert a screwdiver inside the plastic end piece and flex the end of the hose inward and pull the old end off. To install the new end, bend the end of the hose into a "kidney bean" shape and push the new end on.
Jan 02, 2011 | Kirby G6 Bagged Upright Vacuum
Expanding hose cracked near top plastic juntion where alum pole slides in. Need to know if it's possible to remove hose from plastic, shorten slightly to replace split section and reinstall hose to...
I don't know if it's possible to remove. But, something I often use for cracked plastic is a plastic weld.
Just take a soddering iron and a cheap peice of plastic (I often use the clear constainers salad comes in) and melt it into the hole. It's an easy inexpensive way to fix things.
Dec 18, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Where you plug in hose to use attachments
Hi, Your vacuum should have complete set of accessories when you purchased the unit. Your hose has snap lock system. Just check the accessories you need to make snap connection of your hose. Unless you have the missing parts.
Regards,
Dec 17, 2010 | Fantom Vacums Cyclone XT Upright Vacuum
The motor running the beater bar on ny Electrolux canister vacuum cleaner runs intermittently. It runs about 2 minutes and then cuts off and automatically starts again after a 1 to 2 minute interval. I...
Check all the wiring connections to make sure they're tight.
1/2. Wiring to power nozzle motor or reset switch is loose.
1. Cord from power nozzle to upper wand. If the plastic portion of the wand is cracked near the cord connection, or the connections are blackened, they need replaced.
2. Wiring connection from hose handle to upper wand. Check for cracks and discoloration as in 1 above. Replace if necessary.
3. Hose connection to vacuum. Not likely, but possible.
4. There could very well be a break in the hose wiring.
You may need to take your vacuum, with hose and power nozzle, to an authorized Aerus Electrux service shop. They can try a new hoze to see if that's the problem. If there is a break in the wiring, the hose is probably worn in other areas as well, and should be replaced.
Oct 16, 2010 | Electrolux UltraLux 2000 Bagged Canister...
When i press the trigger for water to come out it doesn't?
there is a very weak plastic plunger under the trigger on the hose, if that is the one you are speaking of. mine broke shortly after i bought it. i just bought a replacement hose and used epoxy to build up the trigger for holding it's position better without snapping off.
Jun 05, 2010 | Bissell 9200 Upright Vacuum
Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Bissell 6590 wheel unit pins snapped, where can I get a replacement part
This is a very easy repair. I got a hose clamp. 1/2" wide, solid edge. Take your time and bend it the inside shape of the holder. drill 2 matching holes, It's a perfect fit.
Nov 02, 2008 | Bissell 6590 CleanView Bagless Upright...
Utlimate g vacuum appholstery attachment
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic cup with two hooks on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier.
Since you lost your manual, you may want another. They are available in DVD, VHS or book format. Check it out!
http://stores.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_KIRBY-OWNERS-MANUALS_W0QQcolZ4QQdirZ1QQfsubZ7656839QQftidZ2QQtZkm
Hope this helps...
Marci
Jun 02, 2008 | Kirby Ultimate G Bagged Upright Vacuum
The blower attachment
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic cup with two hooks on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier. Since you lost your manual, you may need belt change instructions as well. Here is a link to my online guide that will show you how....
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
Hope this helps...
Marci
Oct 25, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
258 people viewed this question
Top Royal Vacuums Experts
Electroboy
Electroboy
Are you a Royal Vacuum Expert? Answer questions, earn points and help others
