Question about Xerox CopyCenter C118PL Copier
The machine says my copier/scanner has failed to initalize . what do i do ??
Lanier 5518, all my copys are dirty with black patches and black streaky lines on the full length of the paper , its obvious that too much toner is being transfered, can I adjust the amount of toner used please help
Posted on Feb 13, 2011
  • 239 Answers
This problem might need a Xerox Serivice Rep to repair the machine.
Sometimes the scanner motor fails, needs to be replaced.
The drive cable might be loose or have broken gears on the drive motor.
For indepth solutions, call Xerox, hopefully the labor and parts are included in the call charge. Xerox will warrenty the service for 30 days.
Posted on Oct 16, 2009
Solution for unable to Init.43 repair
To clear the message, you need to disconnect the Brother machine from the power outlet to check the machine. Follow the steps listed below: Check for foreign objects, such as a paper clip or scrap of paper, inside the machine. Disconnect the machine from the power outlet and open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely. If the error continues to appear, move the print head and examine under the print head. NOTE : The images shown below are from the representative product and may differ from your Brother machine. 2-1.Disconnect the Brother machine from the poweroutlet. 2-2.Open the scanner cover by pulling up on the lower right corner of the cover. 2-3.Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area. 2-4.Gently move the print head to the center. Caution Be careful not to force the print head to move. If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us". 2-5.Examine under the print head. If anything is found, remove it. Hint Use a flashlight if necessary to check thoroughly. 2-6.Close the cover and reconnect the machine to the power outlet. If the message continues to appear on the LCD, the machine will require repair as the print head has failed and will need to be replaced.
May 29, 2014 | Brother Sealed Mfc-j430w Wireless Printer...
Machine init 4f
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Jan 08, 2014 | Brother MFC J220 - multifunction fax /...
Scanner Init error!!
some solution ? i have the same problem :(
Jul 10, 2012 | Oki Electric Industry Oki MC560N...
My Hp Laserjet M1120 MFP showing message "Scanner Error 6"
switch off the printer, then remove all cables connecting to the printer but just the power cable.
-then press and hold the *(start/symoble) and 5 button togather and turn on the printer.
-continue holding the button till you see "perment storage init" displayed and releas the button.
-then at a given point of time the printer will ask you to change laguage,time,date etc.
if this does not sort the issue service is required
this is work on 3055
so i think this work on your printer
Jan 04, 2011 | HP LaserJet M1120 MFP All-In-One Printer
HP Laserjet 4345MFP Backlight on printer display does not light. Counts up the 256MB memory then HP logo (3 sizes) appears (just visible) The 3 lights keep cycling on the display. Thats it, does nothing...
HP Laserjet 4345MFP
The 3 lights keep cycling on the display. Thats it, does nothing else.
It has been left overnight and continues to display the logo and cycling 3 lights.
Rear DC Cont Fan is turning. No other fans or activity with machine.
When ADF/scanner/mfp or hard disk are disconnected it does recognise this and throws an error and asks for reboot.
I have tried cold reset, nvram init. and hard disk init. but no difference.
Your thoughts?
Aug 27, 2010 | HP LaserJet 4345mfp Printer
52 scanner error
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
if the above step does not resolve the issue, please repair/replace the machine
Nikhil Gedam
Dec 11, 2008 | HP LaserJet 3050 All-In-One Printer
Scanner failure during the initalization/starts up.
Sound as if your scanner is broken..
Could be something in there stopping it from moving, the motor could be bad.
It might have Home Positioning errors, causing this error.
To get it Fixed? The machine is about 140 dollars on Amazon?
The company I work for, the first hour is 125 (I do not know how much it cost to repair these)
Unfortunately these little ink jet printers are not designed to be repaired. They are considered throw away.
Sorry
Oct 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
Installing printer and scanner
here you go, try to uninstall the driver on your pc, then removed it also on the control panel.. then restart your pc...after you doing all this, try to install again your printer driver..then read and follow the instructions.
thanks..
Feb 24, 2008 | Toshiba e-Studio150 Copier
Xerox CopyCenter C118PL Copier Logo
94 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
