Question about Sony KP-51HW40 51" Rear Projection Television
Lamp or Bulbs for a Sony KP-51HW40 CRT RPTV , The Red bulb is available but the green and blue bulbs are (what I was told) discontinued. They told me that there are 2 different serial numbers for that model number and the green and blue are in very limited supply for the one and discontinued for the other. I asked if the TV could be modified some how to accept a newer style bulb/lamp and I was told no. Do you have any solutions to find the correct bulbs?
  • 119 Answers
SOURCE: Sony KP-51HW40 No Picture, only sound
how many thimes does the light blink, it's an indication as to where you should start looking for the cause of the problem
Posted on Dec 21, 2006
Slinteriors
  • 8617 Answers
SOURCE: Sony 57
I have never heard of two CRts being shorted at the same time. I would suggest calling another shop as They are most likely trying to take advantage of you. Go to the following link and leave an email indicating your model number and one of their techs will email you back and ask you to explain your symptoms.
heres the link.
http://servicemanuals.vstore.ca/
Posted on May 17, 2008
  • 3 Answers
SOURCE: KP-51HW40 Sony 51" Fades to blue screen
The service manual on page 8 shows how to adjust the Red/Blue/Green screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Posted on Sep 06, 2008
  • 4 Answers
SOURCE: Blue screen after 5 seconds took the back off and saw Green Lamp turn off
Just fixed mine with the same problem you all described:
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Posted on May 19, 2009
  • 4234 Answers
SOURCE: Sony - KP61XBR48. I need to know a model of the replacement Lamp
First of all, there are no lamps inside this set, there are CRTs. These are not just replaced as lamps would be. The CRTs themselves will run at leas $80 each. To change these will require replacing the coolant for the CRT as well which is not a DYI type of job. The coolant is dangerous and needs to be handled carefully. Also, once a CRT is replaced, a complete mechanical and electronic convergence adjustment must be made. There is a specific order in which to do this that is outlined in the service manual and it requires a template that would need to be purchased as well.
Unless there is a specific problem that needs to be addressed, it is unlikely that any of the CRTs needs to be replaced.
If you are having a problem with the set, can you please update this with a description of the problem? We should be able to assist in the resulution of the problem with something less drastic than CRT replacement.
Thanks,
Dan
Posted on Nov 20, 2009
Testimonial: "Very informative and fast reply"
How do i replace the bulbs for sony KP-51HW40 t.v.
You do not have any bulbs in this set. You have 3 CRT's. You can not get them anymore. You would have to pull all 3 out and send them in to have them rebuilt. For the cost of that, I would purchase a new TV.
Apr 14, 2011 | Sony KP-51HW40 51" Rear Projection...
All three bulbs are flasjing - color is washed out a bluish grey
The issue on these TV's is the CRT's are failing. This was a very common problem with these series of Sony projection TV's. The original CRT's are no longer available but there are suitable replacement CRT's, but they then all HAVE to be replaced at the same time. The part numbers are as follows for the new CRT's. Please take a few moments to rate my answer. Thanks...
BLUE CRT A-1502-022-A
GREEN CRT A-1502-025-A
RED CRT A-1502-021-A
Nov 20, 2009 | Sony KP-57HW40 57" Rear Projection...
Looking for lights....
You can find replacement parts for this model from the following Sony OEM parts distributor. Here's the links to order the original Sony blue CRT, green CRT, and red CRT (the 3 "light bulbs") for this model from that major parts distributor if needed:
Sony KPR-53CX35 Replacement Part Blue CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Green CRT Bulb / Lamp
Sony KPR-53CX35 Replacement Part Red CRT Bulb / Lamp
Apr 01, 2009 | Televison & Video
Sony kp-51hw40 I need to know were the red crt is.
If you take the front cover off and look at the bulbs, you will be able to tell which one is the red bulb. Looking at the front of the TV, the red shhould be on the left. If you need a red bulb, I have one that works fine.
steven162@centurytel.net
Sep 27, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-53XBR45 Bulbs
you can get this bulb at any local electrical shop if you take the sample of your old bulb to show the shopkeeper.also take the take the perfect model number of your tv.
and to check how the board is and how to replace the parts on the boards and many more help please click this link for further help.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Sep 24, 2008 | Sony KP-53XBR45 53" Rear Projection...
KP-51HW-40 FLASES BLUE ,RED, GREEN
Your picture tubes are trying to short out you have 3 red, green ,blue.
Mar 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Green bulb for projection tv
I found the lamps at PartStore.com for $146 plus ship/hand/taxes
Feb 02, 2008 | Sony KP-53HS10 TV
Sony KP-51HW40 51" Rear Projection Television Logo
230 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
