Question about Refrigerators
We have a side by side refrdge no refridgeration
  • 832 Answers
Check your thermostat setting, and set it at little below the maximum level. Put it on. Can you hear or feel the
compressor running? If this running, observe if freezer gets cool. If not, you can have the technician assistance. Have you refrigerant level checked, and
reload appropriate level to get the fridge working. E-mail
to us the result.
Posted on Oct 07, 2009
How do you start up the water coming on a ge side x side dr refrdg/drzr the waterline is connected
If this is a new start up you must flush the air out of the filter and the holding tank by depressing the water dispenser for 2-3 minutes until all the air is out.
Feb 25, 2010 | GE Refrigerators
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I purchased a Kitchenaid Refridgerator 6 months ago. I changed the filter at the bottom about 3 weeks ago. Ever since then, my refridgerator has a bad odor. I have completely cleaned the refridgerator and...
If you purchased this machine NEW 6 months ago, everything on it is under warranty. You should contact the selling dealer to verify you are entitled to a free service call. Changing the filter is routine maintenance and in no way should affect the warranty.
Oct 25, 2009 | KitchenAid (KSRD22FKST) Side by Side...
MAYTAG REFRIDGERATOR NOT COOLING
Check to see if the evaporator fan is blowing. Sometimes removing the back panel to expose the fan and hand turning it can make it come back on. If this doesn't work then the fan is bad. Also make sure that there is good circulation to the fridge side. Food can sometimes block air flow.
Jul 01, 2009 | Maytag MSD2651 HE Side by Side...
Refridgerator problem
Not sure about your model, but most of these style side by side refridgerators use the cold air from the freezer to cool the refridgerator. Sounds like your "flapper" valve is broken. At the top left in the refridgerator there should be plastic shroud. Remove it and your flapper valve should be under it. You will most likely find the flap broken off of it. You may have success using epoxy to glue it or you may have to replace the valve assembly.
Good luck.
Apr 20, 2009 | Frigidaire FRS26H5AS Side by Side...
GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Apr 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Refridgerator side of my refridgerator keeps freezing my food
The problem may be low gas or it may be the thermostat is set too low.  First, look at the possibility that you may have the food partly blocking an air channel which is where the very cold air is coming from..  Fridge side should read about 40 F after the door is closed for about an hour.  If colder, adjust.
Nov 15, 2008 | Refrigerators
Refridgerator
IF THE BUZZING SOUND IS ONLY THERE WHEN THE MOTOR IS RUNNING THAT COULD MEAN ONLY ONE THING.YOUR PISTON IN SIDE THE COMPRESSOR IS NOISEY THE ONLY WAY TO SOLVE THAT IS TO REPLACE THE COMPRESSOR.BEST YOU HAVE A TECH TO ADVICE YOU FUTHER.GOODLUCK.MOHAMED
Jul 21, 2008 | Whirlpool ED2FHEXN Side by Side...
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
