Question about Coleman Powermate Powermate 5000W Generator
Wire connection to my powermate 5000 on/off switch broke off where can I get another one it doesn't show up on any schematic I've found..
    Champion:
  • 205 Answers
Go to the web side under powermate. you have to relize powermate went out of bussness in march
Posted on Oct 12, 2009
  • S Harlan
    S Harlan Oct 13, 2009
    im going to see if i still have the cd in fill i'll get back to you
  • S Harlan
    ok i need the model and ser number off the unit
How do you remove the start stop switch mounted on the rope pull housing on the coleman 5000 powermate 7500 watt unit. You can't get the housing off without removing the start stop switch.
without seeing it, they usual have enough lead length to allow the cover to be moved so you can get to the wire, The switch usually has a blade with a slide connector that can be removed.
Oct 12, 2014 | Coleman Powermate 5000 Generator
Need a wiring diagram/schematic for the power output end/recepticals for the coleman powermate 5000 model pc0545305.01 generator
Couldn't get you a wiring diagram but the contact info should get you to someone who can. The other links will get the manual and parts breakdowns.
http://www.powermate.com/contact.php
http://www.powermate.com/pdfs/2007/11/12/manual_pc0105000.pdf
http://www.powermate.com/pdfs/2007/11/12/parts_pc0105000.pdf
Oct 01, 2012 | Coleman Powermate Powermate 5000W...
Engine quit while running and now no spark.
Does the flywheel magnet still have a strong pull on it?
Mar 20, 2017 | Coleman Powermate Portable Generator...
Want to add 240volt outlet to generator
You CANNOT do this, USA 240V is derived from a poly phase scenario, IE 120V line to neautral and 240V line to line, UK 240V is derived from 1 line to neutral it will not work unless you power a transformer
May 16, 2012 | Coleman Powermate Powermate 5000W...
Coleman Powermate 10 hp Briggs and straton engine model 19G412, On Off switch broke at base of switch, not sure how it is hooked up, one black wire with a metal prong contact present and not sure if I need...
Yes, If there is room I would use a spst toggle switch. This is a very common switch. Try ebay, HD etc. If there isn't a similar switch can be found at ebay. Good Luck
Oct 14, 2017 | Coleman Powermate Portable Generator...
No AC out put
After working on several of this style coleman generator,i have found that the lead wires in the windings that are soldered to where your brushes would contact tend to break.I don't know if it's a poor design or just a fluke,i would check to see if your getting continuity on the rotor and go from there.They seem to either "burn off" or just break.
Mar 09, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate on/off switch broke off. Is a DIY out of the ?
there is a wire in the back of the control pad...right behind the on\off switch...once it touches the naked body of the gen. it will shut off..
Sep 29, 2009 | Coleman Powermate Powermate 5000W...
Hello I have a coleman powermate 5000 that i need a wiring diagram for the brigg and stratton moter some of the wiring has be destroyed and i need a diagram to get it back running can you help me PLEASE....
I can't get a wiring diagram or a manual without the model. type, and code off the engine.
What I can do is describe the usual wiring and see of that helps.
The ones I've worked on have a very simple wiring harness,
a black wire runs down into the front of the engine, this is the kill wire that attaches to the ignition module (coil), the other end of the kill wire connects to the center terminal of the on/off switch.
A white wire runs from the switch to the oil shutdown module, at the switch it's connected to the terminal that's closed when in the run position. The other switch terminal connects to a wire that runs to the frame ground. The gray wire from the oil sensor module connects to the oil sensor on the side of the engine.
That's pretty much all of the wiring there is for an engine that doesn't have electric start.
Rate me please,
Carl
Dec 03, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
464 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
