Question about Olevia Televison & Video
Olevia 542 LCD TV will not turn on. If I unplug the TV, wait 5 seconds, then plug it back in, it will turn on and operate normally in all functions. If I then turn it off it will not come back on without unplugging and re-plugging. Any ideas? I have already seen solutions for other Olevia TVs that had similar problems (involving capacitors on the power board or the ceramic fuse) but none for the 542 with this particular problem. Thanks in advance.
SOURCE: To kb8ez re: Olevia power supply problem
necesito el power alimentador de energia de mi tv LT37HVS Olevia
espero respuestas mi correo es luis19rpm@hotmail.com
Posted on Jul 10, 2009
SOURCE: Olevia lcd tv will not turn on.
First you want to unplug the tv for a few hours to reset settings. Plug it back in and then switch the master power switch off and then on.
There is a master Power Switch next to the power cord receptacle, make sure that this switch is on the on position and the blue LED in the front is illuminated (Note: The switch in the rear of the television is in the on position when the line is depressed).
This should get your tv working again. Just needs a good powercycle.
TECH just worked on a tv I just tried it on.
Posted on Feb 25, 2010
freelance-au
  • 131 Answers
SOURCE: I have to unplug and plug back in to get tv on
This will be down to bad capacitors in your power supply, Take the back of your tv look at the power supply and look for bulged capacitors ( domed shaped on top ) they may also be leaking a brown liquid substance, replace these and that should cure the fault.
Posted on Mar 05, 2010
  • 16 Answers
SOURCE: Tv wont turn on
Replaced two N-Channel Mosfet transistors(FQPF13N50CF-ND) and some faulty electrolytic caps in the power supply. I found the Mosfets online at Digi-Key. Mosfets are difficult to read. Only one read bad but I replaced both because they are in the same circuit. Set works great now.
Posted on Mar 30, 2010
SOURCE: alarm led on samsung pcb model #lj44-00025a
I had a similar problem with my 42" set, a re-badged SAMPO unit bought during 2002 in the UK. It was working one day and when turned back on the next day there was no picture. The clicking noises that occur when the set is switch on happened but not in the usual pattern. The symptoms were the same as a fault it had approximately 10 months after I bought it, although it was then repaired under warranty by swapping out the PSU.
I took the back off the set and confirmed it had the LJ44-00025A PSU board. When first plugged in the green LEDs on the PSU would light and the relays would click. There would then be a short buzzing noise, the relays would click and the green LEDs would go out. The red "Alarm" LED would then light.
After reading posts on a number of forums pointing to the PSU being at fault, I ordered a replacement PSU from ADC in the US ($139.00 + shipping) but that did not fix the problem. After downloading the service manual I then followed the instructions to check and set the PSU voltages, during the time that the three green LEDs were lit. I found that the VA value was zero and the others were a lot lower than they should have been. The service manual shows that the voltage tests are carried out with most of the sub-boards connected, except the Image Board and front panel switches. I then disconnected each connector in turn from the PSU and found that when the connector for the Logic F-Buffer board (LJ92-00601A) was disconnected the PSU would not alarm when powered up and the five voltages were close to normal. I found a replacement 2nd hand F-Buffer board on fleabay for about £17.00 and once fitted I re-tested and set the five voltage levels for the PSU. The TV is now working as well as it ever has. I have since tested the original PSU and confirmed that it also works, although the voltage levels needed adjusting. I hope this helps.
Posted on Jul 06, 2010
Standby light is on,but my olevia tv will not turn on.
No, someone will need to open set and check voltages etc and also look at power board to see if any puffed up bad caps like these:
Apr 18, 2012 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Olevia 542-b11 LCD HDTV won't turn on. Blue light blinks twice
My Olevia 42" television is several years old. In March of 2012, the infamous "TV will not power on" problem started.
The blue LED light on the front of the TV would go off for a split second, then light up again. The television would not start.
If you are handy with small tools and a soldering iron, you can change the capacitors on the power supply. My Olevia is a model 542-B11.
I bought the repair kit off eBay from seller: sghill99
As of this writing, the seller has sold 37 of these kits. The title of the auction is: Repair Kit, Olevia 542-B11, LCD TV, Capacitors
And if the url is still active, it is: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230554940338&ssPageName=ADME:L:OC:US:3160
I made the repairs in March 2012 and it is now August 2012 and the television is still working great. It is turned on and off several times every day.
Oct 25, 2011 | Olevia LT42HVi 42 in. LCD Television
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
TV will not turn on. Sometimes if I unplug it and then plug it back in the blue power light will come on for a few seconds.
computer chip that runs these functions could be screwed up. there could be a short in the wiring inside it. check for manufacture waranty
Nov 03, 2010 | Olevia LT42HVi 42 in. LCD Television
I turn on the T.V. and the blue light is blinking and the T.V. doesn't turn on
1. simultaneoulsy press and hold [menu] and [vol-] on TV side panel
2. press and release [power] on TV side panel
3. count to 5 and release[menu] and [vol-]
4. TV should have turned on
5. if not, unplug TV and press[power]
6. repeat from step 1 if the TV does not power on the 2nd time
Jul 10, 2009 | JVC LT42P789 42 in. LCD TV
Olevia tv
try unpluging, wait about 30 seconds and plug back in.
Mar 23, 2009 | Olevia LT32HVE 32 in. LCD Television
Dec 02, 2007 | Olevia LT32HVM 32 in. LCD Television
Televison & Video Logo
117 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
