Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
I HEAR SMALL CLICK INSIDE OF DRIVE, LIKE THE READ HEAD IS STUCK OR TRYING TO ENGAGE.COMPUTER WILL NOT RECOGNIZE DRIVE BECAUSE IT IS NOT STARTING UP.
    Sergeant:
  • 191 Answers
The drive itself [its header is ]likely damaged. try recovering something from it using ontrack easy recovery or ntfs undelete [those program sometimes are able to read even that much damaged drives] if it won't help you'll require some data recovery company help, as psychical damage of drive is irreparable @ "home conditions "
Posted on Oct 07, 2009
My Lacie 500gb external hard disk has stopped working. it has a scratching like sound and no computer couldn't detect it. even it is not detected in device manager. when it is connected to computers it...
is the scratchy sound coming from inside your lacie or outside ??
it might be a power problem trying to connect to your lacie but unable to find the device or a dirty hard drive the reader arm skipping across the platters you could give your lacie a firm tap on the side to free up the reader arm
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Sep 15, 2011 | LaCie Computers & Internet
Have a question..i was using my external hard drive just fine last night..and it fell off my night stand and now all i hear is a beep sound and now it wont work...any ideas what to do? please help...i have...
Unfortunately the hard drive is toast, the only hope of retrieving data is take it to a well equipted computer service store in the hope of extracting the imformation, this will be hit and miss whether it can be successful.
Jul 09, 2011 | Seagate Maxtor OneTouch 4 Plus...
Does not recognize DVDs, computer
I would like to suggest that you attempt to download & install the codecs that your media player requires, before it will play a DVD.
I found this typical when I was using the Vista operating system with Windows Media Player 11.
The codecs can be found as freeware online & a good site for the apt codecs for WMP 11 is @ www.majorgeeks.com once you are on the site, click multimedia on the left of the page, then scroll down to the codecs required.
The K-Lite series of codecs seem to work well with WMP 11 on Vista.
I truly hope that this has resolved your problem, as there is nothing better than watching a fine movie on the old PC.
Failing my advice, you could always 'Rip' the said movie to your media player & view it from your hard drive.
Good luck anyway.
Warmest regards,
Ste
Apr 18, 2010 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My DVD drive won't open - seems stuck
on the front of the dvd drive, there is a small pinhole that you will need to insert something the size of a safety pin and push inside and that should pop it open and you can pull it open the rest of the way. or you can also try "start/my computer/dvd drive/then rightclick on the dvd drive icon and click "eject". if its not reading disks as well, you can purchace a cleaning disk. the drive may be about ready to quit working so plan on a new one in the near future if possible. hope this helps!!
Jan 15, 2010 | Computers & Internet
Optical drives do not recognize disk when trying to load new disk
If you cannot read those CD-disks in _any_ computer, then the disks are "bad".
If you can read those CD-disks, then it's time to replace the CD/DVD drive. Find a smaller computer-store -- often they will remove the "dead" drive, and install the "new" drive, for $0.00, or for a small fee, if you buy the new CD/DVD-writer from them.
Nov 18, 2009 | Dell Inspiron 530 -Intel® Pentium®...
My disc drive won't eject.
If there is CD/DVD stuck inside:look for a small hole on the face of the drive and insert a paper clip, and press a bit, the drive will open.
If that does not do the trick, look for an icon on the systray (where the clock is shown) . It represents a square inside which there is disk.The tooltip (bubble) should read Optical Drive Power (on or off). If you click on it it shows a two item menu Power On Power Off with a tick mark near one of them. Click Power ON.
Hope it helps.
Sep 07, 2009 | Gateway Computers & Internet
My TSST corp TS-H653R CD/DVD does not recognize that a
HP uses a method to determine if an optical drive has failed. Basically in a nutshell, if the drive will not read a disc, or if it will not write to one, then the drive is defective.
When the diag tool asked you to insert a "data disk" it's not asking for any particular disk, just one with data on it so that it can test itself.
if it does not recognize the disk in the machine, then try another disk. if the issues persist, the drive is definately failed.
hope this helps!
Aug 31, 2009 | HP Pavilion Elite e9180t PC - 3.00 GHz;...
Cd drive stuck shut with disk in it how do i get it open now
use a paper clip fold it out and push it straight in carefully into the eject hole in the cd drive. It is a small hole on the cd drive usually close to the eject button. You will feel a release on the inside. When you push it you will hear it/feel it eject. Don't push real hard as you don't want to bend the paper clip and get it stuck in the hole
Aug 08, 2009 | Fujitsu AMILO Pro V1000 Notebook
CD drive will not read my discs and does not recognize cd in drive.
Try to run a head cleaner on your laptop drive CD/DVD drive. After cleaning if it still does not read any discs, then it probably time to replace it.
May 30, 2009 | Dell Latitude D600 Notebook
CD/DVD drive stuck CLOSED and NO pin hole
Use my computer and select the drive (eg drive E:). From pull down menu "File" select "eject". While the disk door attempts to open (hear slight movement of tray) massage the door with your fingers. This is done by smoothing out the across front door panel with your finger tips and pushing in and releasing pressure from door. Door should slide open partially and close again. Repeat. The eject button nearside the disc tray doesn't seem to work as well as selecting "File" and "Eject" from the menu. Something to do with the door cycle is less with the direct eject button.
Jan 28, 2009 | Zenith Data Systems Zenith (OP-260-74501)...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
166 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
