Question about Dryers
31 year old dryer the glow plug gloes but the gas will not fire
  • 121 Answers
You will need to change the selinoid coils on top of the gas valve. that should solve your problem.
Posted on Oct 12, 2009
Glow bar may be cracked it will still glow but does not get hot enough
Posted on Nov 12, 2010
    President:
  • 1,922 Answers
Either the flame sensor "EYE" or the control board is not sensing the flame and shutting off the gas supply for safety
Posted on Oct 09, 2009
The gas valve will not fire, the ignitor glows but no fire from gas valve
replace your ignitor even if it is glow there is current that need to pass in the ignitor wire and if it is not getting to that current it will not kick on the gas valve , even if it is glowing.
if it is more then 4 years it is that :)
Mar 26, 2011 | Dryers
I have a gas Kenmore Dryer 74202200 and it heats sometimes, moreso when it first comes on. The glow plug works and it clicks and it fires up, but then the fire shuts off and the glow plug comes back on a...
if it runs for the first 15 to 30 minutes and then no heat you have bad gas coils,located on top of the gas valve,when the coils heat up they fail,if you try to start it again after it sits for a long time it will lite again,also you could have a bad gas valve,try tapping the valve to see if it lites,if it does lite while you're tapping on it most likely it will be the valve,let me know what you find and send the model number.good luck
Jul 26, 2010 | Kenmore 63942 Dryer
Amana NDG2335AW Gas Dryer runs but doesn't heat
Check the spark ignitor when firtst starting the dryer up. It should click within the first 15 seconds to light the pilot up
May 31, 2010 | Amana NDG2335AW Gas Dryer
My gas dryer is not heating up I checked to see if any flames is on when its running but its not coming on the timer is turning.what needs to change
All gas dryers have a gas module. The older models (very old) have a pilot light and the new ones have what is called a GLOW PLUG and it is made out of ceramic. If this glow plug is in any way broken, you will not have any heat. The GLOW PLUG is what comes on when you first turn the dryer on and it GLOWS until the gas module actually spits out a small amount of gas and an internal combustion occurs and the flames come on full power and this is what dries your clothes. If the GLOW PLUG is fine, then the gas module could be bad. ALSO, Always check for burnt wires and check any thermostats or fuses internally in the unit.
Nov 16, 2009 | Whirlpool Dryers
The dryers does not light
I will be happy to assit you with this issue
I have a web side that will help you.
http://www.youtube.com/watch?v=f1rebeCMVsk&feature=fvw
was this helpful?
your rating is very important so I can help others.
thank you
Oct 18, 2009 | Kenmore Dryers
Maytag gas dryer-plug glows but flame will not kick on
gas solenoid bad. replace. not opening up on its own til you hit it
Jun 21, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Kenmore 80 series Gas Dryer
HI. you are correct. this dryer, although gas, is using a Glow igniter system. most older models used the snap igniter that clicks over and over to spark the burner but, this dryer is only 2 years old so, it should be outfitted with a glow igniter system. This igniter is powered by electricity.
It works in conjunction with a Flame sensor.
Jun 02, 2009 | Kenmore Dryers
GLOW PLUG WORKS BUT ONLY STAYS LIT FOR 30 SECONDS
HI, there are a set of coils on the gas valve assembly that have gone bad. these coils are responsible for the opening and closing of the gas valves. your coil assembly is damaged, in return, causing this interruption.
simply replacing the coils will fix this issue.
May 28, 2009 | Amana Dryers
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Kenmore Elite Gas Dryer 7 years Old Mod# 110 72982101
Make sure your vent duct is not clogged up. If the machine can't breathe properly it will short cycle the burner.
If this is ok, it sounds like the flame sensor has failed. Also, the thermistor should not read open, it should have some resistence. It changes depending on the temp. Open the back of the console and you should have a tech sheet that gives all the readings and diagnostic checks.
Post back to this thread if you need help going through it.
Oct 23, 2007 | Kenmore 63942 Dryer
Dryers Logo
69 people viewed this question
Top Dryers Experts
