Question about RTO Atwood Water Heater - 6 Gal LP
Atwood water heater light doesnt stay on
The light that indicates that the water heater is working, usually stays on for 5 seconds and then goes off, in order for me to have hot water i have to keep on pressing the switch. I change the circuit board for a new one and it did not solved the issue. Thanks
  • John Coristine
    John Coristine May 11, 2010
    I'M CONFUSED. THE LIGHT SHOULD GO OUT INDICATING THE UNIT HAS IGNITED THE LP AND IS WORKING FINE. PLEASE EXPLAIN.
  • RTO Master
  • 6,674 Answers
That light in the switch should only be on momentarily while it is igniting, and then go out when everything is ok. If light stays on, it's to alert you that for some reason, the burner did not ignite, such as propane is off, or some other reason it didn't ignite. If the light stay out, then the burner should be working properly.
Posted on May 04, 2010
Water heater will light but only stays lit for about 5 seconds then shuts off
sounds like the flame sensor isn't detecting the flame. It could be dirty or broken.
It's normally dirty so that could be fixed easily. Look in your owners manual to see where the flame sensor is (it usually looks like a metal rod with a bend on the end and just one wire coming out the bottom).
Turn off the power, remove the sensor, clean it with emery cloth and replace it, turn on and if that was the problem it should work just fine now.
Jun 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
I have an Atwood water heater model G6A-8E. When
If this model has a thremo couple you might want to check it. It sounds like that is the problem.
Jun 07, 2010 | RTO Atwood Water Heater - 6 Gal LP
My atwood 6 gal water heater gas with electric light comes on and runs for a few seconds then goes out,if i turn the switch on several times it will stay on.can you help with this problem? thanks
Try cleaning the electrode that sits in front of the flame, as well as adjusting it,if necessary to make sure it is in front or at least in position that it senses the flame well.
Feb 16, 2010 | RTO Atwood Water Heater - 6 Gal LP
The pilot light & will stay lit. untill the burner cycles on/off
MAKE SURE THE BURNER TUBE AND ORIFICES ARE CLEAN. MAKE SURE YOU HAVE THE PROPER LP PRESSURE.
Oct 05, 2009 | RTO Atwood Water Heater - 6 Gal LP
Atwood water heater problems
probly the sensor on the modul. Take and clean it off with emery cloth and then reinstall it.
Jan 21, 2009 | RTO Atwood Water Heater - 6 Gal LP
RTO Atwood Water Heater - 6 Gal LP Logo
260 people viewed this question
Top RTO Water Heaters Experts
Donni Steen
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
