Question about Projection Televisions
RCA Scenium HD65W140 problems
I have a RCA Scenium HD65W140 with picture problems. One day it was fine and the next no picture only week signal message displaying. Tried unplugging overnite but no difference. The menu can be viewed onscreen but no reception picture. Any help woulbe be appreciated.
4 Suggested Answers
  • 3130 Answers
SOURCE: Picture is snowy on every channel
If one tv looks good and another one dosent look good or operate correctly then we know for sure that the problem is not the antenna. Now the menu comes up ok because the menu is injected after the tuner into the video curcuit from a osd or microprocessor. sounds like you could have a defective tuner or antenna block assy.
Posted on Mar 28, 2006
  • 8617 Answers
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
Posted on Jan 15, 2008
SOURCE: rca scenium turns off and on
I wish I had the idea to install a cooling fan, a local repair shop fixed mine by replacing a power supply component, cost $575 including sales tax. I suspect that a cooling fan would increase the life of the power supply, I will install one!
Posted on Dec 04, 2008
  • 5138 Answers
SOURCE: I have an RCA HD65W140
You can Ship boards for repair if you are unable to solder and replace componets.
You first need to Look the Deflection board for Poor Solder Connections and Bad Capacitors
CP150 2200uf 16v use 25v CP114 and CP120 220uf 35v, If CP 150 is swollen or vented on Top then replace all 3 capacitors. Deflection board is the bottom Left hand side and next to it on Right hand side is the SSB board. If the Deflection board is OK ,then replace the SSB board.
PTS rebuilts boards 1-800-844-7871
UED 1-800-648-6657 Has Replacement boards also.
Posted on Aug 07, 2011
0 characters
1 Points
No picture/sound
here are some contact information for rca
Questions about operating or setting up your
HDTV: Call us toll free at 1-866-SCENIUM
(1-866-723-6486), or send us an email.
Quality comments? Call us toll free at
Jan 06, 2008 | Projection Televisions
RCA Scenium 52 DLP
you should take it to a tv repair shop to look it over, they charge $50 and they will tell you want the problem is.
Dec 17, 2007 | RCA Scenium D40W20 40" Rear Projection...
Colors over lapping lll
convergence is off, convergence ICs need to be replaced
May 27, 2010 | RCA Scenium D40W20 40" Rear Projection...
RCA Scenium
What does the picture look like when it is on?
Dec 03, 2008 | RCA Scenium D40W20 40" Rear Projection...
I'm in need of the reset code for my RCA HD65W140 '' RP'' TV
our tv has a line about 10 inchs down that makes the picture distorted -on the bottom about 3 inchs up is black you cant see any of wording if there was any annoucements being posted.
Nov 22, 2008 | RCA HD65W140 65" Rear Projection...
Rca scenium turns off and on
I had the same problem with mine. It was overheating. I installed a small cpu cooling fan on the back of the unit. No problems since. Good luck.
Nov 08, 2008 | RCA D61W130 61" Rear Projection Television
l have a 42 in tv rca connected from a direct satellite and i have no picture or sound tryed different connecters only black screen with unsable signal
Jan 07, 2008 | RCA HD65W140 65" Rear Projection...
This is a terrible thing to tell you, but, what you describe is called dijitizing then the light engine failed Now it gets real bad ,,, This part 261589 is about $590.00 and is on factory backorder with no ETA in site. We have been waiting for one of these at our shop now for over 5 months. RCA knows about this problem and you might want to give them a call and see if they will do anything
Projection Televisions Logo
Top Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Projection Television Expert? Answer questions, earn points and help others
