Question about Ricoh CL4000DN Laser Printer
Error SC491 - Ricoh CL4000DN Laser Printer
3 Suggested Answers
newport74
  • 58 Answers
SOURCE: sc491 error on ricoh MPC 3500
Sc 491 straight from manual
High voltage power: Drum/ development bias output error
An error signal is detected for 0.2 seconds when charging the drum or
development.
 High voltage leak
 Broken harness
 Defective drum unit or development unit
 Defective high voltage supply unit
1. Check or replace the harness.
2. Replace the drum unit or paper transfer unit.
3. Replace the high voltage supply unit.
Posted on Feb 26, 2010
deniricoh95828
replace drum black and swing to drum yellow....
Posted on Dec 08, 2015
I have Ricoh mpc2050 copier and there is an error coming SC491. Cant get copies.. If anyone have solution please reply
  • Code: 491
  • Description:High voltage power: Drum/ development bias output error
    An error signal is detected for 0.2 seconds when charging the drum or development.
  • Causes:• High voltage leak • Broken harness • Defective drum unit or development unit • Defective high voltage supply unit
Oct 14, 2017 | Ricoh Office Equipment & Supplies
How to reset Ricoh mpc2030 color copier sc491 error
you can't reset this error by software!!!
Most often there is a problem with charge leak in one of the drum units, or paper transfer unit. Try first with replacing most used PCU (maybe the Black one). If you have old and used drum unit try to use it again. Drum is the same for all colours. If you stop charge leaking, the error will dissapear after restart.
Pif
Dec 04, 2015 | Ricoh Office Equipment & Supplies
IN PRINTING AN ERROR SC491 IS GIVING.KINDLY REPLY WITH SOLUTION.
Polygonal Mirror Motor Cooling Fan Motor Lock
The polygonal mirror motor cooling fan motor lock signal remains HIGH for 5s while the polygonal mirror motor cooling fan motor is on.
Oct 15, 2015 | Office Equipment & Supplies
Service call sc491
Most likely a bad PCU (drum unit) causing the issue/error code but hard to reply in more detail if you don't provide the model number of you Ricoh/Savin/Gestetner/Lanier copier.
Aug 26, 2014 | Office Equipment & Supplies
My Ricoh SPC811 DN shows always an error code SC491
hi
this error code is about "Cooling fan motor lock", we have 2 Reason for this code,1: Cooling fan motor defective or a loose
object is interfering with the fan and 2: Poor fan motor connector connection
please check them
Oct 06, 2013 | Ricoh Brand Aficio Spc811dn WASTE DISPOSAL...
RICOH MPC2500 ERROR CODE SC491.What is the problem?
please visit ricohservice.blogspot.com endcoder from ITB maybe dirty...
Jun 12, 2012 | Office Equipment & Supplies
Printer Error SC491 Problem
sc491 is a high voltage output error. Combined with your jamming issue, it sounds like a possible electrical problem somewhere. A good first step is to turn the machine off and unplug it, then take off the covers and reset any connections or cables you can get to.
If the problem persists, you should have a service technician take a look at it because it might need a board replaced.
SC491 error is a general error meaning service needed
Jul 04, 2011 | Office Equipment & Supplies
Ricoh Aficio SP C420dn Printer. The printer at
Apr 27, 2010 | Ricoh Aficio SP C410DN Laser Printer
Sc491 error on ricoh MPC 3500
development.
 High voltage leak
 Broken harness
Nov 16, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh CL4000DN Laser Printer Logo
255 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
