Question about Kohler 3386-6 Rialto Skylight Round Front Toilet
Toilet doesn't flush hard enough and some "particles" remain and need to be flushed a second time.
    Top Expert:
  • 12,902 Answers
Check water level in tank if low adjust float to proper level inside tank will see a level line also check flap as to opening all the way may have to adjust chain if problem continues hard water can cause build up in water holes and narrow tank to bowl tube
Posted on Oct 07, 2009
Kohler flush problems
If it has a power flush (i.e hole about 1" in size opposite side of flushing direction) that hole gets plugged by minerals from the hard water, when it does the flush will be much weaker. To clean it, use a bent coat hanger and ream out the deposits as far in as you can reach. Then turn off the water supply, flush the toilet, then quickly pour one pail full of water into the toilet to drop the water level to minimum. Get "Lime Away" at H/Depot, pour in 1 cup and let sit overnight to eat the remaining hard water deposits from the bowl and power flush. In morning turn on water flush a few times, should wok good as new. Repeat anytime hole starts to get plugged.
Aug 21, 2014 | Home
Toilet flushes but does not have the power to flush down waist
Aug 14, 2014 | Home
Toilet wont flush
Jul 27, 2014 | Home
My toilet doesn't flush every time I flush it! It only flush If I pour a little more water into toilet bowl while water coming down toilet bowl! I've checked water level in tank and it was full...
I think the problem with your toilet bowl is in the tank fitting of it..you better check if the fittings are proprerly working..You also check the flapper and also the fillvalve.
If it is not good already you can replace it by buying the tank fittings at the hardware store..And you better also be check it to your plumber for the second thought..
Jun 17, 2011 | American Standard Home
Glacier Bay 1.28 GPF HET All-in-One Elongated Toilet bowl doesn't flush with enough pressure.. I have passed a fish to unglog anything and even my father brought over a fish for clearing the toliet...
The 1.28 GPF rating may not be sufficient to ensure thorough flushing action. The flapper could be affecting flush action as well.
Feb 16, 2018 | Home
Dear sir/madam. when flushing toilet it takes a
Some water saver toilets are very problematic about not having enough water to thoroughly flush. Here are 2 things to look for:
First, after toilet stops running completely, check the water level. Most tanks will have a "full" line marked inside. If the water level is low, your fill valve will need to be adjusted.
Second, if the water level is fine, your "flapper" valve (very bottom of tank) may not be opening all the way. Watch valve as you flush the toilet. It should come up far enough to allow total unobstructive flow of water. If it isn't, adjust chain length until it does. Make sure there is a little slack left.
If neither of these solves your problem, you may have a partial clog that will need to be gotten out with a drain snake that can be purchased at any hardeware store.
Jun 08, 2010 | Home
This is a commercial toilet with a g-2 sloan valve on top. The amount of water dispersed is fine, but there is something wrong with the throat of the toilet, I think. The drain action is somewhat slow...
The blockage MAY be beyond the length of the snake you used. Once I had a blockage that required 145 feet of snake. ALSO the vent could be plugged by any of several things, including wasp nests.
Nov 04, 2009 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Oct 24, 2009 | Kohler K-11470-0 White Wellworth Complete...
Noise of flush water
You have two issues inside of the toilet tank. The holding down the button is caused by your chain not being tight enough from the handle to the flapper. Take the slack out of that and replace the flapper. The second is that you need to replace the fill valve. This is what is making the noise when the tank is being refilled, and will have to be adjusted after it is installed.
Please remember to rate this.
Apr 07, 2009 | Toto CST414M-11 Aquia Dual Flush Elongated...
Kohler 3386-6 Rialto Skylight Round Front Toilet Logo
514 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
