Question about Maytag EPIC MFW9700S Front Load Washer
Hello, I have a Maytag washing machine MFW97005Q0
Hello, I have a Maytag washing machine MFW97005Q0 that is giving me an error code of FH . It first started doing this about a year ago . I cleaned out the screen on the water valve body and it started working again up untill reciently. Now I have tried everything with no good results. The FH code comes on when the machine is first filling and also when filling for the rinse cycle. Can you help me solve this problem ?
  • 2 more comments
  • ken_gimblet Oct 07, 2009
    I have replaced the water supply lines and the valves are fully open . The drain seems to be working fine . One other thing , the cloths softener despenser and the bleach despesser do not seen to be despensing properly as well
    Hello, 88smokey has not responded back to me yet bout my problem with my maytag MFW9700S washing machine with the FH code. His suggestions were very basic solutions that I have already tried . I get the code when ever the machine is filling with water. also. the bleach and softner despensers do not always empty . I previosly cleaned out the screen on the enlet valve that stopped this problem but the problem has returned and I can not get it to stop. The book told me that i had a water flow problem ( FH ) not a drain problem . It looks like I have enough water flow . I have not checked water presure but nothing has changed outside the machine to change that . There is a flow senser on this unit as well . I could use a good answer before I give up and call in a tech . Thanks for your help.
    Taran, I have water comming in and there seems to be a good flow.
    1- the drain pump is operating
    2-I don't know what or where the pressure switch hose is but I have no water leaking
    3-I am not sure what a siphon problem would be the drain hose is at the proper heigth and goes into a 4 inch soil pipe . I don't here any water running out
    I have checked wire harness connections at inlet valve. Is the pressure switch you refer to the thing that the water goes through right after it comes through the inlet valve I assume that this is the flow meter ? if so , I have checked these.the drain pump works fine , I do not see any leaks .
    How would I varify; pressure switch operation and flow meter operation or even CCU operation ?
  • ken_gimblet Oct 14, 2009
    Yes the solution was helpful . I suspected the flow meter as the problem but I did not know just how to test it so I could verify the problem. I installed the new one and the problem quit . I just hope that this is the end of my problem. Thank you very much. Ken
  • 10,515 Answers
Regarding FH error - No water detected entering machine or Pressure switch trip not detected.If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.Also, If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2.
Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
  • If there is water in the unit:-
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation.
Note - If you are not handy at electronics, better to call a local tech.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 07, 2009
  • taran_2005
    taran_2005 Oct 07, 2009
    Thanks for your response!!
    As far as Pressure Switch Hose is concerned, Sometimes you will find that the pressure switch hose has come off the air dome.
    The above one is the image of the pressure switch hose.
    Now,
    The procedure to test Pressure switch is :-
    http://www.acmehowto.com/howto/appliance...
    Follow the above guide to check pressure switch function.
    Verify flow meter operation by blowing air through the part and measuring the resistance and Verify CCU operation by running a Diagnostic test or any cycle.
    Hope i helped you.
  • 708 Answers
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible
Also make sure your hoses are not kinked.
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Maytag Epic FH Error
follow this steps .God bless you
F/H No water detected entering machine or Pressure switch trip not detected.
Or
  • If there is no water in the unit:
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
Jul 22, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Timer display blinks fh on maytag epic front loader
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Inlet valves can be purchased thru the net and fitted by you easily.
Feb 25, 2013 | Maytag EPIC MFW9700S Front Load Washer
Whirlpool duet washer fills with water washes for about 12 min then code hf
The FH error code means that the washer has not detected any water entering it. This tip i wrote relating to the FH code covers what to checkto fix it.
http://www1.fixya.com/support/r10423905-fh_code_means_duet_epic_front_load
GENE
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
FH IS FLASHING ON THE WASHER AND IT HAD STOPPED WORKING ONLY 5 MNUTES INTO ITS CYCLE
The FH error code means the computer on the control board didnt detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the scrrens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced
GENE
Sep 11, 2011 | Maytag EPIC MFW9700S Front Load Washer
FH SIGNAL MEANS ......... WHAT IS THE USE OF FH SIGNAL........ AND APPLICATIONS
The error code FH means no water is detected entering the machine which can be due to a faulty flow meter not registering the correct amount of water that has passed through it or the pressure is not tripping from the empty position to the full position when the correct water level has been reached. Your machine is definitely made by Whirlpool like other Kenmore and Maytag washing machine so they are basically the same and troubleshooting is then the same. The link below contains the detailed troubleshooting of this error code for a Whirlpool Duet and should be applicable to your machine.
Error Code FH on Whirlpool-made Front-Load Washers
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
Washer starts and runs for about 10 minutes. Then stops and gives error message HF
Hello & Welcome to FixYa
FH error code is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Mar 07, 2011 | Kenmore HE3T Washer
F11 error code
The F11 code means there is an electrical with the Maytag Epic washer. This could involve wiring, fuses or a number of other issues.
Press the "Pause" button twice to stop the current cycle. Press the "Drain" button to remove any excess water. Try to run the washer again. If the F11 code repeats, shut the washer off and contact a service agent
The FH error code may be mistaken for the F11 code. The FH code signals a water supply issue and has nothing to do with electrical problems. Check the LCD screen to ensure you read the proper code
Dec 28, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
267 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
