Question about AKG C1000S Professional Microphone
Akg c1000s replacement grille
Frustrated seeking repair! akg c1000s knocked off mic stand at church. Grill was detached and can't be re-attached. Is there any solution other than throwing it away? No luck trying akg for replacement grille. $130 for total top end assembly replacement!!?
    Problem Solver:
  • 5 Answers
Maybe you could find a local music store that repairs equipment to replace the grill. Sometimes you can find parts on websites like Ebay.
Posted on Oct 28, 2009
C1000s hum/buzz on phantom power
possibly the microphone needs more power than your sound card can supply although I cannot imagine as the duet is a good piece of equipment.
Is the duet USB bus powered?
Have you tried another cable? Possibly one wire is defective which means that phantom power will superpose the audio signal. In this case you might hear a hum. By the way this results in 6dB of signal loss. This is why XLR plugs have 3 wires. If connected with a 1/4" jack it has to be a stereo plug (tip, ring, sleeve)
Mar 26, 2014 | AKG Audio Players & Recorders
Can I plug in a C1000S mike into a Sony WM-DC6?
Sure. You need a cable or adapter that fits the mic's canon plug into the recorder's mic jack.
Buy one at Radio Shack, or Amazon, or eBay, or Full Compass - http://www.fullcompass.com/category/1-4-To-XLR-Adapters-Transformer-Type.html .
Jul 03, 2012 | Audio Players & Recorders
My AKG C1000S shows a weak signal from one side of the two stereo channels when I use an XLR going to a 1/4 inch Stereo jack. Does the mic only work properly with a Mono jack?
You have connected the mic improperly. You'll need an XLR to 1/4" transformer to properly match the impedance, then run into a mono channel.
Mar 15, 2012 | AKG C1000S Professional Microphone
Barely has any output. i thought it was low battery but it was not. what could the problem be?
If this is a (phantom) mic, it has to be plugged into a phantom plug on a mixer (round black thing with 3 metal posts in the middle. Darren Kelly-themasterofthrowdown@yahoo.com
Apr 28, 2011 | AKG C1000S Professional Microphone
Hi, I'm trying to fit the polar pattern converter to my C1000S mic. I've removed the wire mesh part to reveal the shock mount and capsule but there seems to be a black plastic bit of a different shape...
Alan, the C1000s comes with 2 filters, and it sounds like one of them is already on the capsule. Yes you can remove the one already on. I find by gently twisting and pulling it comes off easily. The capsule is rubber mounted so it can take a little bit of pressure.
Feb 27, 2011 | AKG C1000S Professional Microphone
First two burners work fine but when I turn on third burner (back) it cuts out the whole grill on the Weber genesis
This is very common with faulty regulators. The regulator is located on the hose (it is a metal silver disc located at the end of the hose where the hose attaches to the propane tank.)
To replace the hose and regulator, you need to detach the hose from the grill. Your local grill store should have replacement hose and regulators.
Hope this helps.
-Ben
Tanks 2 You Propane
propanetanks2you.com
Jan 27, 2011 | Weber Genesis Silver B Grill
I have three working AKG C1000S. They all need grills. Who can I trust to service or sell grills?
AKG sells the replacement screen and tube assembly direct from AKG Acoustics, U.S.
+1 818-920-3237
akgusaservice@harman.com
They are expensive, $80.00 each.
Oct 25, 2010 | AKG C1000S Professional Microphone
How can you open an AKG 220 perception mic to repair it? the mic got knocked over and still works, but the inside seems loose, moving around from side to side.
at the bottom of the mic where the xlr connector is you'll find a ring screw with two notches. unscrew this and you con remove the lower housing. The upper housing is hold by 5 screws.
May 13, 2010 | AKG Perception 220 Professional Microphone
AKG C1000S Professional Microphone Logo
641 people viewed this question
Top AKG Audio Players & Recorders Experts
Vito Vacirca Jr.
Ben Armstrong
Edward Carrington...
Level 1 Expert
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
