Question about NEC NP2000 Multimedia Projector
Projector turns on for 30 sec, status light blinks red 6 times then repeats.
Gigatech
  • 259 Answers
SOURCE: Status light blinking red
If it is a lamp error try this:
When the lamp exceeds 2100 hoursof service, the projector cannot turn on and the manu is not displayed. Do the following:
For VT670/VT470 Press the help button on the remote control for a minimum of ten seconds.
For VT570/VT47 Press and hold the power and the exit buttons on the remote control simultaneously for a minimum of ten seconds. When the lamp time clock is reset to zero, the lamp indicator goes out. Hope this helps! :]
Posted on Feb 27, 2008
SOURCE: No Picture on my nec VT676 model
Thanks. NEC did not have a solution for us, but the solution for us was to replace the bulb. You'd think they would make that a bit more obvious!
Thanks.
Posted on Mar 27, 2008
Gigatech
  • 259 Answers
SOURCE: Blinking status light
6 cycle (0.5 sec On,
0.5 sec Off) is a lamp error!
0.5 sec Off)
Lamp fails to light. Wait a full
minute and then turn on again.
Even though the lamp is not old there may be a defect in the lamp. I know the lamps are expensive but this may be the problem. If you have a lamp that was removed due to age but still worked you could use the lamp to test it.here is a link to the user manual:
http://www.iusb.edu/~libg/ims/VT570_MAN.pdf
Hope this helps. :}
Posted on Apr 02, 2008
SOURCE: Blinking Light on Mitsubishi SL4SU Projector
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
Posted on Mar 23, 2009
  • 23 Answers
SOURCE: NEC VT595 Projector - Status light blinks red constantly
Hi Craig,
If you get no lamp light at all coming from the main projection lens then odds are the lamp ballast or power supply has failed. These can usually be repaired & is a common fault among the VT series projectors. If one of the fans are stuck the unit normally still lights up for a few seconds up to 20 seconds or more until the extra heat trips the safety shutoff & shuts down the projector.
REPAIRS:
If you
Posted on Nov 16, 2010
Does a lamp error message (6 blinking red status lights) mean the lamp needs to be replaced? or could something else be wrong.
According to NEC technical support, if the status light flashes red six times, this could indicate a defective lamp. If a new lamp is installed and the project still won't turn on, the projector will need service.
Jun 15, 2011 | NEC NP400 Projector
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Sony kdfe50a10 blinking green light
did you find out the answer to this problem as we have the exact same issue? thanks
Sep 22, 2009 | Sony (XL-2400) Projector Lamp for...
Status lamp blinking orange 6 times
PROJECTOR. NEC VT491 THE STATUS LIGHT IS BLINKING 6 TIMES RED, AND THE POWER LIGHT IS ORANGE
Jun 26, 2009 | NEC Office Equipment & Supplies
NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
May 28, 2009 | NEC VT595 LCD Projector
Laptop won't start-up
Can you tell me if the status lights on the power adapter and/or the battery turns on? Because you are telling me the status lights only stay on for 30 seconds, this should be a power connection problem.
One other possibility: can you tell me the climate environment of where you use your laptop?
Nov 16, 2008 | Dell Inspiron E1505 Notebook
Replacing the lamp with an old one was helpful for me. Good news: the projector itself not faulty. Bad news: I have two projectors with the same issue at the same time (the lamps were replaced also at the same time) after only 400 hours of running.
Apr 01, 2008 | NEC VT47 Multimedia Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
NEC NP2000 Multimedia Projector Logo
438 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
