Question about Zanussi Washing Machines
I have a Zanussi ZWF1241W and something is stuck in the drum. The drum does not spin freely and prior but does not have any play. What is the best way of checking this and getting the obstruction out. Thanks Bob
It was a sock wedged between the lip of the spinning drum and the outer (stationary) drum casing. I managed to ease it out with some pliers - rotating the drum and pulling. Be careful though not to nick the door seal (as I did). It may be a better strategy to get the door seal off and then remove the obstruction. I'm about to find out how easy/hard/fiddly it is to get a new door seal onto this machine!
Posted on Oct 09, 2009
I had someone out today to try repair my zanussi jet system washing machine as it wouldn't spin, the engineer said that is something stuck between the drum and liner and he can not repair it
Not a very good engineer, so I that has suggest you contact another more reputable one. It is a case of removing the rubber seal between the drum and liner and fishing around inside if that is the case. Can you manually spin the drum in either direction? If it moves freely then there is nothing stuck in there and it may be the actual machine program or spin activation at fault.. If it moves in only one direction can you hear something catching? In which case he may well be right. My guess would be that it is an underwire from a brassiere.
Nov 10, 2015 | Zanussi Washing Machines
On spin cycle sounds like change or rocks spinning around in drum.
Could be a bad bearing or something loose on the drum that doesn't rattle until you get up to spin speed. Look for something like pins, nails or screws stuck in the holes of the drum, or possibly under the protuberances (fins) inside the drum. Does the sound occur all through the spin cycle or only at top speed?
Jul 08, 2015 | Washing Machines
MY zanussi, ZWI1125, FRONT LOADER, now makes such a noice on washing and spinning. the plumber has relevelled it but it still makes a noice esp on spinning. Why?
This could be something stuck in the drum ie ,A bra wire or could be bearing trouble an engineer could tell you within seconds.
Oct 30, 2013 | Zanussi Washing Machines
I have a Zanussi fj1254 w. It was making a high pitched squeel when it was spinning. No when I turn it on water goes in but the drum does not turn. It turns freely when rotated by hand. i have checked the...
Possible that the drive output to the drum is not there and so there is no voltage when the cycle come to the spin mode.
Check for fault in the drive, capacitor to the motor.
Jan 21, 2013 | Zanussi FJ1254W Front Load Washer
Zanussi zwf 1221 will not turn drum, the end light flashes the water goes into the drum and drains out when a program is selected but the drum will not turn at all. You can turn it by hand and it moves...
you need to check the pressure switch inside the washing machine there a small hose connected with the pressure switch to sense that the level of water inside the drum is ok if this hose blocked the machine will not run
Oct 10, 2011 | Zanussi ZWF1430W Front Load Washer
Washing machine drum wont spin or turn by hand
If you cannot turn the drum by hand, then the main drum bearings have probably seized up, or there is something stuck between the inner and outer drum.
Nov 16, 2010 | Zanussi Washing Machines
Foreign object stuck between drum and casing
this is a problem that can only be solved by a professional so please get your local repairman on the line and have him come and take a look.
Jun 11, 2010 | Zanussi ZJD1219 Front Load Washer / Dryer
Grinding sound - drum turns then nothing - just grinding sound until E20 warning.
Can you turn the drum by hand.E20 relates to a fault with either the pump or the filter or drain may be blocked,check the filter is clean and the pump can be turned by hand,its up at the end of filter housing and can be seen depending on the model.If the drum cant be turned freely then you have something stuck inside the drum.
Hope this was helpful.
May 02, 2010 | Zanussi WJS1265W Front Load Washer/Dryer
My clothes are coming out smeeling musty
I have a zwf1241w with similar problem. When I disconnected the drain hose that runs from the drum casing to the pump housing there was a lot of collected debris that had prevented the water from draining through properly. You could try clearing this out.
Oct 06, 2009 | Zanussi F1045W Front Load Washer
Washing Machines Logo
143 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
