Question about Cameras
My canon is not working like it should it wont
My canon is not working like it should it wont let me see the picture i took and will not let me record videos
Preview butto on canon 40d wont showpics on screen
In the menu's you can choose how long you want to view the picture you just took. Settings are off / 2 sec. / 4 sec. / 8 sec. / always on.
I suggest you try everything but off, and it could be exact what you want.
It is the first menu (with the camera pict) fifth row.
Nov 20, 2013 | Canon EOS 40D Digital Camera
My Canon PowerShot A460 cam is working well until yesterday, the biggest festival here in our place took place. teh flash, the lcd screen, etc is working... but, when i took pictures, the lcd screen turns...
Please try and reset the mode of the image to see if the LCD does not go blank when shown to higher light. Also if there is no issue with the indoor pictures then it is possible that the auto light detection is giving a higher value to reset the image balancing. Shift from Auto to manual mode and try.
Mar 18, 2011 | Canon PowerShot A460 Digital Camera
Canon G10 wont turn on
Try removing the card first and then trying to power up the camera. Cameras often fail to turn on/off when a card goes faulty. Next I would try pushing the playback button, it also acts as a power button but starts the camera in playback mode. If this works it could indicate a problem with the power switch circuit itself. If there is still no sign of life I would suspect a fuse to have blown. They are internally located and very small, you would need to have a service centre try replace it for you. Good Luck!
Apr 13, 2009 | Canon PowerShot G10 Digital Camera
My camera screen is black.
If the new pictures are all black, then the problem is not on the LCD display, but it is a faulty CCD sensor.
The CCD image sensor is the device that captures the picture .
CCD sensor is covered even after warranty, contact canon ringing the phone number listed on the owner manual.
Mar 28, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
XT not turning on
I was taking pics with my rebel EOS and it turned off. I charged and changed the battery but wont come on
Sep 18, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon eos 400d
Contact Canon - some makes of lens which are not Canon are not electronically compatible for various reasons, and can actually damage the camera. So, get using the phone and check if it is compatible before doing anything else - but personally, I would not use the lens until I find out
Jul 02, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Black screen
Piece of junk that took great pictures for 1 year and now shows a black screen. Do not buy any Canon products. We also have one of these pieces of junk at work, now displays a E 18 code. Appears Canon wants to make mucho dollars by producing ****.
Apr 13, 2008 | Canon PowerShot S2 IS Digital Camera
Helpppppppppp
Jan. 12/08
I have same printer. No manual. Guess it's too simple and the creators don't think general public need instructions! I am using a Canon S1 camera. My camera screen said to press the "SET" button to print the picture that I had on my camera screen. It worked for me!!! Good luck. I'm guessing printer only prints from a camera, hence it's portability.
Nov 09, 2007 | Lexmark Polaroid P310 Photo Printer
Canon A520 Everything works, except the button you take pictures with. It wont work.
I need more information about what symptoms you are experiencing. I am going to guess that your shutter is stuck closed. This would cause a blank image to show on the view screen and your captured pictures. The regular icons and text would still display normally. Is this what you are seeing? If not please explain further what is happening and I will respond again with more information. David Millier Advance Camera Repair
Mar 12, 2007 | Canon PowerShot A520 Digital Camera
Cameras Logo
14 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
