Question about Philips 32PF7320A 32 in. LCD Television
No data is sent to the screen
I bought a Philips LCD TV model 32PF7320A 4 months ago. About 4 weeks ago the screen started to go black while watching the tv. The sound stays perfect and I can still change the channel and hear the channel change but the picture stays black. I tried it with a DVD and had the same issue so it's not my satellite connection. I also unconnected and reconnected all cables a number of times but this did not help.
  • ibrahimmaged Oct 08, 2009
    The led is working but no picture on the screen (every thing is working except the picture)
  • ibrahimmaged Oct 21, 2009
    finally i found out the problem (it was a fuse)
    Novelist:
  • 128 Answers
When the screen goes completely black, shine a very bright flashlight closely at the screen. If you can see the image, then the most likely problem is that the backlight inverter has failed.
The inverter is a circuit board that works like a flourescent light ballast. If the inverter fails, there is no backlight, and the screen is black.
Since the invertor is a high-voltage component, I would also listen for any unusual sounds associated with the failure: e.g. buzzing, whistling, popping.
To rule out some sort of connection failure, see if you can recreate the failure mode when using the TVs internal setup menu. The setup menu does not rely on any external inputs....of course neither does the volume control or channel indicator on the screen.
Posted on Oct 07, 2009
    Problem Solver:
  • 4 Answers
OK person above me is rite but yes there is a little light in the TV don't maybe need to be change it cause a lot to just for the light OK....are maybe Ur picture tube yes just bad
Posted on Oct 12, 2009
My Phillips Plasma tv MENU pops up unasked and obscures screen.
there is a soft ware upgrade for that problem on there web site you can down load it to a thumb drive and upgrade your set
Oct 31, 2009 | Philips 32PF7320A 32 in. LCD Television
Screen started to go black while watching the tv.
yes, by canging the bulb. it proboly went out while the television was already dead. you can try but i would hire a proffesional. it may cost 100$ or more.
Oct 11, 2009 | Philips 47PFL3603D LCD TV
My Philips flat screen tv model 37PFL5332D/37 will not come on...what should I do to reset my tv
The only way to reset it is to leave it unplugged for 24 hours. If resetting it doesn't help let it turn on, you may have to replace the power supply
Jul 09, 2009 | Philips 32PF7320A 32 in. LCD Television
Want to know if my flat panel tv is prepared for digital change?
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=FLAT_TV_CA&sct=LCD_LARGE_30_40_SU&session=20090118163435_71.196.251.239&grp=TV_GR&ctn=32PF7320A/37&mid=Link_UserManuals&hlt=Link_UserManuals
I also have the pdf form of the user manual , please email me for it,
jscruggs420@gmail.com
Jan 18, 2009 | Philips 32PF7320A 32 in. LCD Television
32 Philips hd flat screen #32pf7320a/37b on for a time,then black
check the capacitors in the power supply that is the first thing to do, just check if anyone is swallen or pregnant jajajaja that's how some people call it
Dec 15, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
GV42L
I had this same problem. Vizio sent someone out to replace the motherboard. It didn't fix the problem. Since it was under warranty, they replaced it with a newer model VU42L. Doesn't have this problem, but it has others.
May 02, 2008 | Vizio GV42L 42 in. LCD Television
Philips 32 LCD TV 32PF9541 Black Screen
Sounds like a temperature problem if it takes a while for the problem to happen there are several things u can try and figure it out yourself. 1. Remove the back cover of the tv and turn the tv on. 2. use a hair dryer and apply heat to various boards of the lcd (inverters, power supply and scaler) while applying heat to see what board reacts and makes the tv go dark. More than likely its a defective LCD panel and its just as easy to send it back and get a replacement TV.
Apr 28, 2008 | Televison & Video
Philips 37 flat screen
U better have it checked by a qaulified tech
Sep 09, 2007 | Initial HDTV-322 32 in. LCD Television
Philips 32PF7320A black screen
If the power lamp is flashing 5 times when it does this, you may need a new power supply. Otherwise, I would suspect a bad (solder) connection in the power supply.
Jan 14, 2007 | Philips 32PF7320A 32 in. LCD Television
Philips 32PF7320A 32 in. LCD Television Logo
339 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
