Question about Gibson SG Standard Electric Guitar with Case
Guitar bridge too low and the lower strings are buzzing the higher i go up the fretboard-what tool can i use please?
    Problem Solver:
  • 10 Answers
SG's use finger adjustable rotary bolts that alter the bridge height at a gradient from 1st ~ 6th and visa versa. Each string has a saddle that is then finely adjustable using a small flat head screwdriver.
You should check the neck, frets and nut also...as it may not be the bridge at fault. Use a guide like raeguitars guitar setup tutorial to help you, it explains everything in detail and helped me no end!
Posted on Nov 30, 2009
  • 454 Answers
Most bridge saddles use allen head screws to adjust the height.
Posted on Oct 07, 2009
Guitar string buzz
What you need is a complete set up as your truss rod is out of adjustment and bridge is too low. Your local guitar shop can help you out for around $50.
Nov 03, 2015 | Gibson Les Paul Studio Electric Guitar
EGS44BK4/4 MANUAL
I don't know what guitar this is because you need to be specific about make and model? but to set up your guitar the low E string #6 the height should be 6/64ths +/-a 64th and the high E string #1 should be 4/64ths +/- a 64th you must be careful because it's not just lowering the bridge saddles to do this the adjustment also has to do with the neck relief and the condition of the frets EX. if you have frets that are higher than others because you don't play there in that area the strings will buzz of the tops of those higher frets. you can try to do it and get your guitar more comfortable to play I don't know all the details here? how old, first, second owner makes a difference because of different playing habits of multiple people but if you do it and it works GREAT! but if you have the problems with buzzing and still not able to intonate the guitar it needs to be seen by a repairman for a (1)fret dressing=make all the frets the same height and reshaped (2)proper neck curvature adjustment =relief (3)intonation= putting the bridge saddle's in the proper place so the guitar is in tune with itself up and down the neck these things require a skilled repairman for the results you want and if you don't have the knowledge and training and tools to do these things you will only turn you guitar into a mess playing worse than ever and sounding terrible but don't misunderstand me here if your willing to learn how to do these things it will help you keep your guitar maintained and the cost of doing so down there are books you can buy showing you what you have to do to get your guitar straight and if yours is not an expensive model well then you can certainly try but if that's all you have to play I wouldn't! go buy some experimental cheap ones at a garage sale and learn on those you'll be glad in the end that I was the person who answered your question here before you started to embark on your quest for a smooth playing and sweet sounding instrument and only getting a nightmare in your hands with the roar of GODZILLA post back here for more info and help!
Aug 26, 2014 | Music
High action martin java mahogany 00x1
To lower the action on an acoustic guitar:
Usually just the saddle needs reducing.
1. Remove strings (or you may be able to just loosen them). Remove saddle, sand down the bottom a little at a time. Restring and check action.
The action can be set as low as poss without any fret buzzing or note choking on all strings and on all frets.
2. Repeat 1
If the action remains too high then there are other techniques.
Later ...
Jan 09, 2014 | Martin Guitars 00X1 Java Mahogany Guitar...
I have noticed a buzzing sound generated from the amplifier when I play my low e string
Several possibilities come to mind:
The speaker is driven too far mechanically causing the voice coil to go into a non-linear region.
The cabinet, stuff inside, grille cloth, or even a logo on the cabinet is resonant and rattles.
Your guitar setup is not quite right leading to "fret buzz"
To troubleshoot, reduce volume and see if that helps...
Mar 04, 2011 | Roland Cube 40XL Guitar Combo Amplifier...
How do I lower my strings closer to the fretboard
There are a few different ways to do this, and unfortunately if you have not done this kind of work before you could end up damaging the guitar more than fixing it.
A few things to look for:
Sight down the neck from the top of the guitar looking down along the edges. If you see a concave (banana shaped) bow in the neck, it needs adjustment. Almost all guitars including yours have a neck adjustment rod that can alleviate some of the bow. If however the neck is convex ( higher in the middle) the neck would need adjustment too. You want a very slight bow in the neck to allow for weather changes as wood expands and contracts with the weather.
Other adjustments are down on the bridge. There are usually very small allen or hex key adjustments for each string to raise and lower the action (height) of the string. Again, any adjustments here can also affect the tuning of the string up and down the neck (intonation). The guitar may not end up being tuned at one place one the neck while in tune on another.
I would highly recommend taking this to a music store with a qualified person to adjust it. Many times the action can be lowered and the string height adjusted for better playing ability. You can inform the technician now what you see and what you want done. Also let them know if you have a heavy or light touch on the strings as this can make a difference when they adjust it too. At the same time a lot of them also restring your guitar for you and you may request a lighter gauge of string allowing for better play too. Good luck.
Feb 21, 2011 | B.C. Rich BC Rich Kerry King Wartribe 7...
Buzzing of strings in frets up to fifth fret; seems that the bridge may be low but it's not. Also, too there is more gain in high strings than the fifth and sixth
Sounds like a warped neck, if the bridge isn't low what else would cause the strings to buzz.? With the gain problem perhaps the neck is twisted as
well as bowed. Epiphone are proving to be quite popular but they are built to a price and for beginners they are usually a good choice. Unfortunately some fakes of different guitars are sold on ebay and they often make better tennis rackets than a musical instrument. Unless you changed them the guitar usually has a cheaper Humbucker pickup. Check it's fitting anf make sure there are no loose parts or wiring sitting against the soundboard on the inside.
Try looking down the neck of the guitar and seeif you notice any warp or bend. Overtightening the strings can cause the opposite warp and the strings end up further from the frets. Also try some measuring. The distance between the any string and the fretboard starting at the nut and working down to the bottom of the fretboard. These measurements should be consistant
Also, check the nut to see if the grooves aren't too deep. This could cause buzzing by allowing less distance between the string and the first fret.
Make sure all the frets are seated correctly and not slightly out of kilter at one end.
That should give you enough to keep you busy for a while. There are plenty of reasoins why a string will buzz. I've covered a few mecanical ones but without sounding rude there are also player caused buzz. Depressing the string too far behind the fret can cause it whereas too close to the fret can kill the note. But that's not my field in this situation. Check all the above and then try your fingering. One way or the other that buzz will stop. The best way to check if it's you is to get someone else to try your guitar out and see if the buzz buzzes off :-)
good luck
Apr 07, 2010 | Epiphone Les Paul 100 Electric Guitar
New flying v, 3 strings make rattly sound near end
Are the strings hitting the frets and making a buzzing sound or is it actually coming from the bridge? Make sure the saddles on the bridge are secure. If the buzzing is caused by the fret then adjust the bridge height and/or truss rod. If the buzzing is coming from the bridge and cannot be cured it may be worth investing in an aftermarket bridge.
Jan 08, 2010 | Coffin Case 300VX Flying V / EXplorer...
How do I fix the high action on the dot?
First, try lowering the bridge. Lower it as ow as you can without the strings buzzing excessively. Check the straightness of the neck. You can adjust the truss rod and put a very slight bow in the neck if low action results in too much string buzz in your case. The nut may also be too high but a simple bridge adjustment should do it.
Dec 05, 2009 | Epiphone Dot Electric Guitar
Floyd rose is causing a fret buzz
Raise the saddles on the FR to help take away the fret buzz. Check the neck for curve. If the neck has a VERY slight bow on the fretboard side the strings will be able to vibrate better without buzz. Also might want to step up to a heavier gauge string set if you play in lower tunings.
Dec 05, 2009 | Jackson Dk2m Dinky Electric Guitar
Both the E and A strings of my Washburn acoustic guitar "BUZZ" even when lightly strummed. The guitar has "light" (.012 - .053) Phosphor Bronze strings.
Buzz usually translates to either inadequate fret clearance or poor quality strings or inadequate pressure holding strings against the fret.
The guitar DESERVES using high quality strings and I would look at the manufacturers recommended string weight or your music store should know what to use. The LIGHT strings MAY be your problem.
Nov 03, 2009 | Washburn D10sbc Acoustic Guitar
Gibson SG Standard Electric Guitar with Case Logo
381 people viewed this question
Top Gibson Music Experts
Michial Gueffroy
Virgil Watts
Are you a Gibson Music Expert? Answer questions, earn points and help others
