Question about Kenmore Washing Machines
Washer makes loud metalic clicking/grinding sound when washing and spinning Model number (110.15942401)
  • craiga_45 Oct 08, 2009
    Thanks for a very thorough response. One thing that I don't understand is how to release the console so it tilts back. There are no visible screws at the front or back that hold down the console.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.15942401
There are a few places to check in the washer.
1. The Clutch
2. The Brake system
3. The splines on the agitate shaft and / or agitator
4. The agitate cam and / or gear in the transmission.
Please see the following :
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Following is the Whirlpool / Kenmore operations and maintenance manual describing how the washer works and in particular how the neutral drain assembly works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
You'll be able to see on the Sears site, the internal construction of the transmission. The Agitate Cams and Neutral Drain assembly cogs are plastic and can wear / break over time.
When ours had a major noise / grinding problem when spinning, we tracked the problem to the agitate cams not lifting the agitate gear high enough (less than 1/16" above the gear on the agitate shaft. Replacing it cost less that $15 vs. $170 for a transmission.
If the Drive Brake, Clutch, agitator splines and agitator shaft seem OK, the problem points to the transmission.
If it appears to be the agitate cams, following is a description of how we replaced them.
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
I had the same problem with gear grinding and this solved it.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (16 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Posted on Oct 07, 2009
Testimonial: "Thanks for a very thorough response. One thing that I don't understand is how to release the console so it tilts back. There are no visible screws."
  • oldguy5 Oct 08, 2009
    Depending on the washer that you have, there should either be narrow panels on either side of the console that will pop off with a screw under each one. Remove the screws and the console will tilt back.
    Other Models of the Kenmore have a clip under the ends of the console that can be pushed with a thin putty knife to pop them loose.
    Look again at the diagrams of your washer on the Sears site to see which type you have.
    Look again at the description of how to access the panel and remove the cabinet.
    http://www.american-appliance.com/catalo...
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
LG front load washer.Will not spin and makes loud grinding noise
what is your model number is then we can get started then to get your unit fixed all redy
Jan 22, 2013 | Washing Machines
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer makes a loud skreeching sound when it stops
Can you let me know what the Model number is of your machine? Is it a FAV6800A or FAV9800A. So many folks post non a FAV6800A or FAV9800A machine types in this forum.
If it one of those types and you open the lid and spin the Wash Basket CCW do you here any metal against metal grinding/screeching sound?
Please don’t offer a vote for me unless I can help you DIY the issue or point you to a repair solution. Thank you…..Rich
Apr 02, 2010 | Maytag Neptune FAV6800AW Top Load Washer
WHIRPOOL WASHER LSQ9564MQ0 Started making loud
judging by the description i would say more likely the coupler
its a three peice part that sits between the mototr and transmission, kinda like a clutch,
anyway it is easily repaired
and available on appliancepartspro.com
type in your model number.....
look for motor coupler
Oct 13, 2009 | Washing Machines
Washer loud grinding noise spin stop
if its brand new it shouldnt be making a loud grinding noise id get it checked make sure they removed all shipping bolts
May 17, 2009 | Maytag Washing Machines
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Spin cycle doesn't work with loud noise
yea sounds like a bad motor coupling ( this machine equivelent to a belt).
Mar 06, 2008 | Whirlpool LSR7333 Top Load Washer
Washing Machines Logo
272 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
