Kodak ESP5, duplex, only prints first side
Kodak ESP5, when printing duplex, frequently (more than half the time) fails to display prompt to rotate paper and continue printing. As a result, the 'back side' cannot be printed.
    Problem Solver:
  • 15 Answers
You can try ressting the settingson the printer By going to Menu -> Printer settings -> Reset All settings and hit Ok.
If the issue persists, try upgrading the printer software and the firmware. The link for the upgrade is kodak.com/go/esp5downloads
Posted on Oct 15, 2009
HP Deskjet 970 Some Duplex Pages Printed with One Side Blank
You have to check the settings when sending a print job through
Mar 21, 2017 | HP DeskJet Office Equipment & Supplies
I am printing a brochure that i created on microsoft publisher, but i can't get it to print double sided the right side up for both pages
Hello:
The Brother DCP-7030 supports manual duplex only. When choosing duplex (2-sided) printing, it will print the even-numbered pages first and prompts you to reinsert the pages in a different orientation.
To correctly print the second side of your brochure, you could do one of two things:
  1. Reverse the orientation of the paper when you reinsert if for the second side of printing.
  2. Reverse the direction of the second page in Publisher.
The first option is simple enough. When the Brother driver directs you to insert the paper for the second side, insert it in a rotated position. It should be on the same side, but rotated 180 degrees.
The second option is also easy, but if you want to edit the document in the future, it will involve in some work before being able to edit it.
  1. In Publisher, select all of the objects on the page (pressing "Ctrl" and "A" on your keyboard at the same time will accomplish this).
  2. Right-click on an object on the page.
  3. Choose "Group"
  4. Your objects are now grouped into one item.
  5. There should be a green dot at the halfway point at the top of the group. You can click and drag this dot until the object is rotated 180 degrees. Alternatively, you could go to the menu and choose "Arrange>Rotate or Flip>Rotate Left 90 degrees" twice.
  6. Now when you print, you should follow the Brother driver directions when flipping the paper.
Jan 14, 2011 | Brother DCP-7030 Digital All-in-One Laser...
What does error code 3820 mean for a kodak esp5 all-in-one printer
The error message "Carriage Home detection failed" (error code 3820) can be resolved by following these steps:
To resolve this error:
1.Open the printer access door.
2.Disconnect the power adapter from the printer.
3.Gently hold both sides of the carriage, located immediately behind the print-head, and make sure the carriage moves freely.
•If the carriage does not move freely, contact Kodak.
4.Remove the print-head and ink cartridges.
5.Reinstall the print-head and ink cartridges, making sure each clicks into place.
6.Connect the power adapter to the printer.
7.Turn the printer on, if necessary.
8.Close the printer access door.
If the error continues, contact Kodak.
Sep 07, 2010 | Kodak Office Equipment & Supplies
I have a Kodak ESP5 all in one printer. At first
Call 1800 421 6699
Printhead needs to be replaced.
It free of charge replacment
Feb 13, 2010 | Kodak ESP 5 Printer
Can my esp5 all in one printer ,print both sides of a4 paper. if so how do you do it, ? Mak
Mak,the printer does not have the duplexer to print on two sides of paper,you need to manually flip the paper in order to get it to print on both sides.First of all give command and get the print out on a sheet.Place that sheet again the other side facing down on the bottom tray and give print command.You will get two-sided prints.
Dec 14, 2009 | Kodak ESP 5 Printer
When I print, it says spooling
Go to Control Panel, Printers and Faxes, Cancel any pending document on your Kodak Printer, then delete all kodak icons.
Turn off the printer, Unplug and Replug the USB cable, then turn on the printer. If nothing happens..
Second options: Click Start then select Run Type the word "net stop spooler" then "net start spooler" Then unplug and replug the printer while its on.
Josh
Aug 18, 2009 | Kodak ESP 5 Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Will not print yellow,all yellow will be pink!
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.
May 17, 2009 | Kodak ESP 5 Printer
Is it possible to print 5x7's with the kodak esp5
Print from your computer :
open the picture you want to print
go to :
File
Print
Properties
another windows will pop up and under general you will see different print size and you can chose there the different paper size and print size.
Apr 11, 2009 | Kodak ESP 5 Printer
Cannon MP160 How to Print both sides of the Paper???
Set Duplex Printing (Windows) For details on how to set duplex printing, see below: 1. Select 'Properties' from the Print dialog. Note: Properties may be indicated as Advanced, depending on the application software. 2. Click the Page Setup tab. 3. In the Printing Type section, select 'Normal-size Printing', 'Fit-to-Page Printing', 'Scaled Printing', or 'Page Layout Printing'. 4. Select 'Duplex Printing'. Note: When a media type other than Plain Paper, Photo Paper Plus Double Sided, or Postcard is selected in the Media Type menu, duplex printing cannot be performed. 5. Specify Staple Side. 1. The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. 2. Click the Staple Side drop-down arrow and select the setting. If you want to change the setting, select another value from the list. 3. If necessary, click Specify Margin... and set the Margin width 6. When the setting is completed, click the OK button at the bottom of the window. Note: If a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed on one side of a sheet of paper when printing starts. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side. If Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed front and back alternately for one sheet at a time, when printing starts. Load the paper according to the displayed messages. 7. You will be prompted, while printing, to remove the printed page and reload it in the ASF. 8. Dependent on the number of pages to print, you will need to repeat step 7 until all pages have printed. Back to Top
Sep 10, 2007 | Office Equipment & Supplies
127 people viewed this question
k24674
