Question about Casio Exilim EX-S880 Digital Camera
When turn on lens goes out and then back in
When turn on lens goes out, makes a noise,and then immediately goes back in
Why does my camera turn on, make a weird noise and
hi. you have problem in lens unit and the weird noise come from to focus gear.maybe you go to the beach or dusty place thats why the said dust or sand goes into lens gear. If you can open and try to clean its better but if not bring to service center and request for cleaning and adjustment.
goodluck my friend
Jul 13, 2010 | Casio EXILIM 10.1-Megapixel Digital Camera...
Nikon s220 lens error
The s220 seems to be very susceptible to lens errors, usually associated with the lens barrel being unaligned. It only takes the slightest bump/drop in many cases. Fixing it is a hit or miss solution. http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html Has a good list of possible fixes.
Jul 06, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Camera says
Hi there just like to informed you that 2 reason can make a noise.
1. low or old battery's using.
Solution: replace it if too old or charged it fully.
2. Lens error. Internal lens guide pin if damaged then the camera goes off with bad noise.
Solution: repair or replaced the lens guide pin.
Thanks & waiting for your feedback.
Apr 01, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Kodak digital camera will not stay on. Lens retracts immediately.
Hi. I actually have the same EXACT problem. DId you end up fixing it. If so, how?
Mar 15, 2010 | Kodak Cameras
Camera shuts off immediately after turning on.
camera systems,lens unit,flash unit,mother boradetc,must be defective,so the camera get shuts off.ao take it to kodak service station
Mar 06, 2010 | Kodak EasyShare V1073 Digital Camera
The lens will not retract and it makes a grind noise
I had the opposite problem, my lens would not full extend. It would immediately retract and turn back off. If you take a can of compressed air and blow it out as you cycle it on/off. It should clear whatever is preventing it from closing.
Here is what my problem was and how I fixed it.
What I did was get a can of compressed air (from the computer section) and blow air around the lens as I repeatedly turned it on. It took about five cycles, but I eventually cleared whatever was preventing the lens from fully opening.
Good luck.
Aug 14, 2009 | Kodak EASYSHARE M340 Digital Camera
On the lens makes a clicking noise shutter goes in and out turns.
Did you drop it? if you did you have damaged the gear drive motor for it. Are the batteris good?
Jul 06, 2009 | Olympus FE-210 Digital Camera
Turns on, lens comes out, and then turns off immediately.
I am aslo having the same problems and I am at my witts with it can anyone HELP?
Oct 21, 2007 | Pentax Optio T10 Digital Camera
Cant turn camera on
well just change the lens. probably the system got broken
Jan 22, 2007 | HP Photosmart 735 Digital Camera
Casio Exilim EX-S880 Digital Camera Logo
23 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
