Question about Husqvarna Chain Saw 20" Bar
Husqvarna 345 leaks (over uses)chain oil - Husqvarna Chain Saw 20" Bar
    President:
  • 2,220 Answers
An IPL (exploded parts list) for your saw can found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit produced by Husky that week
The manual and IPL list no way to change oiler output. Your manual (page 16) says
"If the chain lubrication system is still not working after
carrying out the above checks and associated measures
you should contact your servicing dealer." HTH
Lou
One question - are you using bar oil? It is thicker and stickier than most oils.
Posted on Oct 07, 2009
Unable to locate adjustment control for chain oiler model 345 husqvarna chainsaw
Not all 345 machines had an adjustable oiler, it is retro fittable if it does not, however if it hs an adjuster, the screw is located on the bottom of the saw between the cranckcase and the fuel tank, just below the sprocket, there will be an oil symbol and a - and + sign there, the pump is three position, for 13/15/18" bars.
Oct 02, 2011 | Husqvarna Forest & Garden No.967012396 345...
Husky 345 not oiling chain
Remove the chain plate, Clean it , check oil drain and check oil tank cap is air inlket free.
Mar 20, 2011 | Husqvarna Chain Saw 20" Bar
I have a husqvarna 345 with an 18 inch bar and i keep burning the tip up. the oiler is working but its not putting enough oil to the bar. iv checked and found that the oiler is not adjustable and i cant...
At the end of the bar there's a small hole. Every time you fill the oil you should also put some oil into that hole and turn the chain so it spreads into the bearing. The chain oil is not intended to be enough for that bearing. I hope that will solve your problem.
Nov 20, 2010 | Husqvarna Garden
Husqvarna 345 bar oiler
Remove the bar and chain. Start the engine and observe the oil delivery port in the side of the engine case. At a fairly fast speed, the oil should ooze out of the port. If little or nothing, check the pump, lines, and in-tank filter. If ok, clean the bar drive-end holes of sawdust and dirt, especially the small passages that go from the large holes out to the chain groove. Clean the entire groove and the outer end sprocket. Reassemble and test the oiling by running the bar tip at speed in front of a piece of cardboard--it should throw off a thin line of oil after several moments. Hope this helps!
Apr 09, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a husqvarna model 50 chain saw and am not sure of the ratio of the oil & gas mixture.
Husqvarna Rancher 50 1982-11 OM Follows:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS1982/HOUS1982_O8200003.PDF
50:1 according to your manual if using Husqvarna (quality) 2-cycle oil.
HusqvarnaUSA.com
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 01, 2010 | Husqvarna Forest & Garden No.967012396 345...
I can not find the serial number on my 345 husqvarna chain saw. wher do i need to look?
Page 6, item 1
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_1150986-95.pdf
HusqvarnaUSA.com
06 1500198
HTH
Lou
Jan 21, 2010 | Husqvarna Forest & Garden No.967012396 345...
I cant get oil to the chain on my husqvarna 345.
You may have a problem with blockage in the oiler system somewhere. Try emptying out all of the bar oil and swishing some gas around in the bar oil tank to clean it out. This will work some of the time. Sometimes you have to take the oiler off and blow thru the lines into the tank,( make sure the oil fill cap is off) and blow into the oil tank out thru the line to clear out any debris . The adjustment for the oil pump should be on the bottom of the saw. Here is the manual with the procedure on page 32 of the manual. Hope that helps you.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140235-95.pdf
Jun 12, 2009 | Husqvarna Forest & Garden No.967012396 345...
Chain oiler not working
Go to husqvarna.com then US the support then product manuals, look up both saws and see if the part no for each saw is same.
Apr 15, 2009 | Husqvarna Forest & Garden No.967012396 345...
Where is the bar oil adjusted from on husqvarna 345
Turn the Hus 345 chain saw upside down, you may see a little Icon of a oil droplet and a + - arrow by the chain. THe adjustment screw is not pictured in any of the standard user manuals,. but it is a small black slot headed screw over a rectangale metal tab by the chain. I believe if you turn it counter-clockwise, it will give you more oil,, It did for me. If you have the bar off, you can start the saw and see it come out the hole, that would verify your oil pump is working. Make sure the holes on the bar are clean also. running the saw at a fast idle for 1 min should oil the chain well enouth that it starts spraying off the end of the bar when you gun the engine.
Mar 31, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna 345 power loss and vibrates
Replace the bar. Your bar has gone bad and that is why you are losing power. Bars are made by the chain saws to be completely oiled at all times. When the bar does not get oil the bar will start to warp and that is what will cause you lack of power when trying to due a top cut
Feb 14, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna Chain Saw 20" Bar Logo
1,012 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
