Question about Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
Model pvr72160t Lost channel 28 muxB following retune. Signal level/quality 92-98%. Have tried reset. Can you help please?- Geoff
Problem solved by repeatedly (~20 attempts) to make a manual search for channel 28 only. - thanks
Posted on Oct 08, 2009
Why is my Humax 4000 very slow, freezing and scrambled saying bad signal.
Check the signal level and quality. Reseat all aerial connections.
Jun 18, 2016 | Humax Televison & Video
My humax won't;t record bbc channels. I have tried retuning the tv.
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range. The signals for BBC and ITV are among the strongest ones broadcast. If they are now at a point on the aerial's range where they are too strong for the TV then the tuner will over-saturate. The result is the same as no signal.
Have a look online for a Variable Signal Attenuator. It's a device that can be added to a aerial signal cable just before it goes in to the tuner. The adjuster allows the signal level to be reduced. Watch the TV's signal quality and signal level displays if it has them. As signal level (power) reduces you'll actually see signal quality increase. If you go too far then quality will start to go down again. The optimum point is where quality is highest.
Oct 08, 2014 | Humax Televison & Video
JVC LT22HD32J DIGITAL TV WONT HOLD CHANNELS AFTER RETUNE
It's October 2012 and I have a problem with my exact same model of JVC TV which has worked fine since i bought it in January. In fact it has worked the best out of the four that we have in the house working off the same aerial until 4 days ago. I tried retuneing and then the problem expanded to more channels. I tried to reset to factory options and then do a retune but lost all the channels. I have again reset and retuned and I'm back with channels that I can only tune into for between 4 and 15 seconds before the screen goes blank. None of the other televisions are affected. Digital UK website show no works to transmitters in our area and JVC are impossible to contact. Their site sends one around in circles in a most frustrating and unhelpful way. I will not be buying JVC again. Any help offered would be gratefully accepted!
Apr 14, 2012 | Televison & Video
The tv s autostore will not retune
i think in your TV...... design ..... is such that once channels are autostored it cannot be retuned ..... so you try this ...... it may work ......... disconnect tv antenna cable ( or local tv channels cable ) from your TV & then click autostoring (auto tunning ) ..... definitely it will scans (search for channels ) ..... but since no cable is connected no channels will get stored ...... but previously autostored channels will get removed ...... so now again connect your antenna cable or local tv cable & then click autostore ...... it will scan for channels .... like this you can retune ....... but remember again you may get same quality of picture which you got earlier ..... if you want better quality of picture you have to use signal amplifier (increases cables signal's strength - then picture quality improves ) .....
Nov 05, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
Under signal information I've got bit error level 10 and signal strength 0. TV just stopped showing channels. What do I do? Already tried retuning, didn't find any channel.
Hi zaikovskis
I`m going to help you with your tv but first; could i have the brand name and model number?
Should be written on the back of the set.
Mar 31, 2010 | Samsung Televison & Video
CANNOT GET itv1. NEED TO RETUNE BUT DOESN'T PICK
Good Day,
Try this to reset your programming, but try to reset the whole set by unplugging TV and BOX from power source for 3-5 minutes then plug power cord back into power source. If that does not work try this:
Option Menu Setup
Follow the steps below for the initial set-up:
1. Select the "MENU" display by pressing the "MENU" button once.
2. Press the number buttons "0", "1", "7", "0" in sequence to select
the "OPTION MENU" display.
3. Press the "ADJUST" button to select "INITIAL."
4. Press "ENTER."
NOTE: At this time channel 3 is automatically selected.
Good Luck, Big IRISH>
Dec 15, 2009 | Mitsubishi WT-46809 46" Rear Projection...
I am unable to retune my defina32"tv I have lost some of the channels I already had, please help BBC1 ok. BBC2 ok. ch3 invalid channel. ch4 invalid channel.ch5 invalid channel. The list goes on, some are...
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 01, 2009 | Polaroid T730 Digital Camera
Lost BBC channels on my SAGEM PVR6200T during a retune
Jul 06, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Beko 28c723idw has lost all digital channels
Nov 23, 2008 | Beko 324250WN 28" TV
How can I reset a whafdale dvrhd400
Apr 16, 2008 | Wharfedale DVD-M3 DVD Player
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
126 people viewed this question
Top Sagem Televison & Video Experts
electracon
ka4iup
ka4iup
 Mikey
Mikey
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
