The copy is too light. The copy density is set too light. Use the Auto/Photo key to select a darker copy density . The copy paper is damp. Replace the paper. The copy is too dark. The copy density is set too dark. Use the Auto/Photo key to select a lighter copy density . The document was not pressed close enough against the Original Glass. Position the document so that it is pressed closely against the Original Glass. The copy is blurry. The copy paper is damp. Replace the paper. The document was not pressed close enough against the Original Glass. Position the document so that it is pressed closely against the Original Glass. There are streaks through the copy. There are specks throughout the entire copy. The Original Glass is dirty. Wipe the glass with a soft dry cloth. The document pad is dirty. Clean the document pad with a soft cloth dampened with a mild detergent. The original is highly translucent, such as diazo photosensitive paper or OHP transparencies. Place a blank sheet of paper over the document. A double-sided document is being copied. If a thin double-sided document is being copied, the information on the back side may be reproduced in the copy. Use the Auto/ Photo key to select a lighter density for the background. The Imaging Unit has reached the end of its service life. Contact your service representative.
the dark stains are caused by mold build up on the boot of the washer, the e70 may be a pump error. you need to wet a cloth with bleach and then wipe of the mold builldup on the boot, this should solve that problem.
.try xperimenting with diff pc settings wen shooting outdoors...also chk the white balance settings/////focus the camera on the object u want to appear white and "ok" it....chk the iso settings for light sensitivity....if all dis dusnt wrk ...theres a prob wuid ur ccd sensor..and can be repaired only by the service centre.
