Question about Dometic Rooftop RV Air Conditioner
I changed my fan motor and squirl cage blower hooked all wires back like they were fan is not turning fast so the compresser is heating up. the old motor the motor mounts went out that why i changed it
  • Johnny
    Johnny May 11, 2010
    did you check the run capacitor?
  • 788 Answers
If you have changed the motor, I assume that the RPM is the same as the motor you have removed.?
Check the rotation of the new motor, if you have it turning in the wrong direction, it does not matter how fast it turns, it will not send enough air across the evaporator and condenser coils.
Also, if you have changed the motor, you should also change the run capacitor for the power motor.
Hope this info has helped you.
Posted on Oct 08, 2009
    Guru:
  • 588 Answers
Did you replace the capacitor, if not, is it the same mfd and volts for the new motor?
Anytime you replace a motor you should replace the capacitor they don't last as long as they used to and they are inexpensive, a couple of bucks.
If the capacitor is good then most new motors now have the wiring connectiions on the motor, you might check to see if the new motor wires the same as the old motor.
How do you take the squirl cage off the ptac?
Most squirrel cage blowers slide out after removing a screw or two. What system you have? don
Jan 10, 2017 | Heating & Cooling
Amana heat pump emergency heat comes on but blower will not start. The call for heat comes in and the heating element(s) glow red for a few seconds and then there is a "click" and the heating...
Check the blower motor capicator. It should be mounted close to the motor with 2 wires to it (brown,brown/white).
Turn the blower on the thermostat and spin the squirrel cage by hand and see if it runs after by itself. If it does then definitely the capicator is bad .If it still doesn't run then check to see if there is voltage going to motor.
If thermostat is calling for fan and there is voltage present at the motor terminal then the motor is bad
Jun 01, 2017 | Heating & Cooling
Blower Removal
remove cover on top remove cover to fan
Jun 22, 2010 | Dometic Rooftop RV Air Conditioner
So when the fan is turned on it makes some awful noises behind the glove box...
there is squirl cage i call it mounted on fan motor is is the blower something caught in it or blades come apart
Mar 22, 2010 | 2003 Mitsubishi Montero Sport
I have a goodman gmnt 100 b furnace 2 stage when the gave valve turns on and floods the heat exchanger with flame then the squirl cage fan turns on and i loose the the flame
If you are getting flame distortion when the blower comes on it usually means a cracked heat exchanger which can lead to carbon monoxide, get your furnace checked by a qualified tech..
Jan 31, 2010 | Goodman Furnace Draft Inducer Blower ...
Blower motor makig noise like its hitting
You must remove the motor to inspect for bent squirl cage (fan) for damage .your heating issue is seperate from the noise.you could have a bad thermostat check your temp gauge if its at least half way up to 200 degrees thermostat is ok then you will have to check heater core hoses for flow in and out to make sure they are hot. if all check out look at blend air doors make sure they operate.
Jan 06, 2010 | 1999 Pontiac Grand Am GT
I want to clean the squirl cage fan on my Carrier handler. It's 12 years old and never really been cleaned. What is the best cleaning procedure to maximize its efficiency.
The best way to really clean the squirrel cage is to remove the entire indoor blower motor housing assembly out of the furnace then remove the squirrel cage from the motor shaft and pressure wash the squirrel cage. Make sure you don't use to much water pressure as you might knock off any balancing weights that may be attached to the one or more of the vanes. Make sure the cage is completely dry before you re-install it back on the motor shaft.
Nov 16, 2009 | Kitchen Ranges
BLOWER MOTOR REAL HOT
You probably have a shorted starting capacitor. Unless you are familiar with this kind of electrical repair, you should leave this to a professional.
Oct 08, 2009 | Jandy Laars Lt 400,000 Btu Heater
Whwn i turn the heat all the way up loud clicking noise if turned lower noise stops what could this be notfan
I think your talking about the heater fan? If you hear more noise as you increase the blower speed, there is something in the squirl cage or a problem with the blower motor itself. Leaves, paper or something lite on the pass side floor, it will get sucked into the recirculation duct,causing a noise.Remove the blower motor and clean out any debris, and inspect the squirl cage and turn the motor by hand to see if you hear any noise
Sep 29, 2009 | 2005 Ford Explorer
Dometic Rooftop RV Air Conditioner Logo
157 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
