Question about Frigidaire ATF6000ES Front Load Washer
Stops spinning,shows err20 - Frigidaire ATF6000ES Front Load Washer
    President:
  • 1,653 Answers
This is a No Water Detect error. It shows that you have no water coming into the washer insufficient water in the machine after a fixed time period. If the pressure switch (water level detector) has not tripped after 6 minutes, the F20 error code is displayed. This can caused by the following:
If there is NO water in the machine then check the following:
Make sure the water supply taps are on and water is actually available.
Check the water inlet hoses for any damage, creasing or kinks.
The main Water Inlet Valve(s) may be clogged. Remove the hose connectors and clean the meshed inlet screens. They may be scaled up and need descaling before placing back in the hose connectors and reconnecting to the machine.
If the IS water filling the machine then check the following:
Make sure there is not a siphoning problem by making sure that the outlet hose is not laying on the floor or the top of it is too low for the machine specification and the outlet hose is clear, not creased or kinked and has no blockage.
Posted on Oct 07, 2009
How to fix err20 for Canon Rebel T3i?
Error code 20 refers to a detected mechanical problem
Error code 30 refers to a detected shutter problem
-Turn the power switch to < ON > to turn on the power.
-Remove and re-install the battery.
-Use a Canon lens.
-If the instructions above do not solve the problem you may need contact your nearest Canon Service Center.
Aug 03, 2014 | Canon Cameras
Can you explain error code 20
Contact Canon.
http://www.canon.co.uk/support/consumer_products/product_ranges/cameras/eos/error_codes/#err20
Jun 17, 2014 | Canon EOS 600D Rebel T3i Digital Camera
It seems to wash, but it stops and beeps displaying an err20. It is not rinsing or spinning. if we remove everything,but one or two articles of clothing it seems to work fine.
Can you hear the water pump out of the machine. It makes a difference on what to check and I don't you to waste time for nothing.
Let me know
Jan 10, 2011 | Frigidaire GLTR1670A Front Load Washer
How to reset my washing machine (electrolux)
my electrolux EWT606 will not spin. it drains and then just wont go into spin cycle....no error messages it just beeps. can anyone help me please as i have kids with disabilities and NEED to wash!
Mar 14, 2009 | Electrolux Washing Machines
Err20
Hard to find what the ERR20 fault is. Sounds like something is stopping the pump. Are you using HE rated detergent? Sometimes you get a sud's lock on the pump, or something jamming or blocking the pump. If it wasnt HE detergent, it may have locked the pump down. Let me know how it turns out. Good Luck!!! Jim
Sep 08, 2007 | Frigidaire GLTR1670A Front Load Washer
Err20 No drainage
remove the hose from the outlet and lay it as flat as poss into a bowl. fill the machine up and see how much water starts to run out. if there is a lot then there may be a blocked outlet instead. the way to attempt to clear a waste hose out without removing it is to buy a flexi unblocker (like a bendywound wire) from a handyman shop and ram it up the hose. tone.
Jun 09, 2007 | Zanussi FJD1466S Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
110 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
