Question about Brother HL-2070N Laser Printer
Need help resetting the drum on HP 2070N. Drum is changed. Light is still on. Thanks!
    President:
  • 787 Answers
You need to have the front of the printer open, when you press and hold the "Go" button. All four lights will come on, in sequence. Release the button, and close the front cover.
Posted on Oct 07, 2009
Testimonial: "Perfect! Thanks!"
  • tishbru Aug 31, 2010
    Thanks so much. I tried several things and your was the first suggestion that said to make sure the front of the printer was OPEN. That was an important detail!
My drum light keep flashing. How do i fix this problem?
if the drum light is flashing, and the ready light is on,
it means that your drum is nearing end of life and will need to be replaced soon.
thanks adi
Jan 26, 2010 | Brother HL-2070N Laser Printer
Drum light still on when toner has been replaced
You need to replace the drum and reset the printer for that to go away, open the front door and hold the go button til all lights flash and the drum is reset. If quality is OK you can keep using the old drum. If you press the go button 3 times it will give a report showing the life left in the drum.
Oct 01, 2009 | Brother HL-2070N Laser Printer
Solid black line at the left side of paper after reset the drum
Try moving the blue panel to clean the drum after you install the toner.
plus before you do that, you need to clean up your drum by using the duster.
May 18, 2009 | Brother HL-2070N Laser Printer
Brother printer HL 5250 DN. The drum light was flashes and I have replaced the drum kit and toner cartridge.
Brother Drum Reset Instructions
The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Reset the drum counter only when you replaced the drum unit with a new one.
Dec 05, 2008 | Brother HL-2070N Laser Printer
Brother HL 2070N Drum Unit changed but printing with dots on the left hand side
If toner leaked into the machine and got on the fuser that could cause this, but the dots would go away after a few prints. Try another drum unit.
Oct 28, 2008 | Brother HL-2070N Laser Printer
Replaced Drum in printer won't print
Unplug it then plug it back in and check for anything in the device. Or leave it unplugged for a few hours and try again.
Apr 16, 2008 | Brother HL-2070N Laser Printer
HL 2070n
Copier tech here. :P I just had to look this up. looked to the internet first, before going to find a manual.
open front door (the door for toner and drum units)
hold Go untill all four lights are on.
Release Go
Shut door
good to go.
Have a good night ya all.
Mar 28, 2008 | Brother HL-2070N Laser Printer
Brother HL 2070n
Check the website of brother. If they allow you to download and update its firmware. Update the firmware and driver as well.
Mar 24, 2008 | Brother HL-2070N Laser Printer
Toner light still on after replacing with a new one
Drum counter usually has to be reset.. Check user manual or go to Brother's site if you want to drive yourself crazy Ed
May 04, 2007 | Brother HL-2070N Laser Printer
Printer drum light on
Have you already replaced the drum? If you have not replaced the drum that may be why you are getting smudges. If you have already replaced the drum, here is the reset procedure. The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one. The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below: Open the front cover of the printer. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button. Close the front cover. CautionReset the drum counter only when you replaced the drum unit with a new one.Related Models HL-2030, HL-2030R, HL-2040, HL-2040R, HL-2070N, HL-2070NR http://www.tonerovernight.com
Mar 31, 2007 | Brother HL-2040 Laser Printer
Brother HL-2070N Laser Printer Logo
446 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
