Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage Door Opener Intermittingly Reversing
Craftsman Liftmaster 1/2 hp door opener intermittingly reverses 3 inches from fully closed...will always go down once button is pushed to stop and then pushed again to close door. No obstructions, sensors are aligned and steady. Happens about 25% of the time, day or night, wet or dry, etc. Help!
  • 1 more comment
  • Anonymous Feb 07, 2008
    Garage door closed this morning and when I came home it won't open. The door acts as if it will open by the sound of the chain but it won't budge
  • Anonymous Jan 01, 2009
    my garage opener will go down but 12 in from closing it will come back up
  • Anonymous Mar 18, 2014
    door stops midway, does not close fully
    President:
  • 4,402 Answers
Try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Posted on Jan 10, 2008
My Craftsman 1/2 Hp garage door opener doesn't stop going down despite (quite forcefully!) applying pressure in the opposite direction. It would buckle (and did) if I don't let it continue unhindered...do...
YOU NEED TO ADJUST THE DOWN FORCE.
YOU WANT TO TURN IT COUNTER CLOCKWISE TO THE STOP (THIS ADJUSTMENT IS ONLY ABOUT 3/4 TURN FROM MIN. TO MAX.). THEN TRY THE DOOR IF IT REVERSES TURN IT ABOUT 1/16TH TURN CLOCKWISE. CONTINUE THIS VERY MINOR INCRAMENT ADJUSTMENT UNTIL THE DOOR CLOSES WITHOUT REVERSING. THEN GO 1/16TH TURN FURTHER.
YOU SHOULD BE ABLE TO STOP THE DOOR AND REVERSE IT BY GRABBING THE BOTTOM OF THE DOOR AS IT GOES DOWN AND LIFTING SLIGHTLY. IF YOU CAN'T GET THE DOOR TO BOTH CLOSE AND REVERSE WITH MODERATE PRESSURE YOU MAY NEED ADJUSTMENT TO THE DOOR / SPRING / ETC.
- I DO NOT RECOMMEND ADJUSTING THE DOOR YOURSELF - CALL IN A PRO FOR THAT.
IF THE ADJUSTMENT IS SUCCESFUL ADJUST THE OPEN SENSITIVITY / FORCE IN THE SAME MANNER.
HOPE THIS HELPS
Jun 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: Can I bypass the sensors on my garage door opener?...
You cannot bypass the sensors but you can try reversing their position so that the sun isn't hitting the receiving unit. You can also move them back from the door or use something like the tube inside a roll of toilet tissue to shade the lens.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Reversing sensor blinking
Tweak the sensors to see if you can stop the blinking. They must be pointed at one another and not blinking for them to work properly.
Dec 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens 4 inches then reverses and stops
you need to replace gear when the door is fully closed. then do your tweaking.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener does not reverse after hitting obstruction
release the door from the opener and see if door moves freely the check proper torsion by moving door up to 3-4 ft if it stays in this area torsion is properly set if not call technician to adjust torsion
if door does not move freely all the way up and down check for binding track alighnment and roller condition. the adjust closing pressure.
Jan 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
611 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
