Question about Hotpoint WMA30 Front Load Washer
I HAVE A CREDA WASHING MACHINE WMA30 IT DOES
I HAVE A CREDA WASHING MACHINE WMA30 IT DOES NOT HEAT WATER
I CHECKED OUT HEATER CONNECTION AND RESISTANCE OF HEATER IS FINE
I NEED THE SERVICE MANUAL THANK YOU
    Problem Solver:
  • 16 Answers
There is a thermistor in between the heater terminals .. unplug the block from it and check to see that the thermister has not gone open circuit
Posted on Jan 23, 2010
Whirlpool washing machine not heating water
the machine does not heat the water . a seperate water heater does that
Jun 13, 2014 | Creda W100FW Front Load Washer
Service manual for "Insert water spout" problem
Check the heating coils for proper resistance or no resistance. If the machine is sending a signal to check the coils before turning them on AND it is not getting any resistance then it cannot continue. However if you have the machine plugged in near the microwave oven, then a power surge may have blown the control board or caused it to lose its progamming. The control board is expensive!
http://www.appliancefactoryparts.com/smallappliances/delonghi/esam5500-b-perfecta.html
Nov 24, 2013 | DeLonghi ESAM5500
Hotpoint wma30. Drum not draining water. Have
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
Creda Simplicity 1000 (w100fw) - Drum does not rotate
you could try fitting new motor brush kit it wears down after 4/5 years and need replaced....please leave feedback
Apr 08, 2010 | Creda W100FW Front Load Washer
The error F23
This error occurs when heater fails in the unit .
Try this
  1. Unplug power chord to the washing machine .
  2. Check connection to water heater .
  3. Check resistance of heating element .
  4. Check the water temperature sensor and connection to it.
Hope this helps .
Feb 21, 2009 | Whirlpool Washing Machines
Creda Simplicity 1000 Washing Machine not heating water
Make sure that you have not got the energy save button in operation, as this by-passes the heater, and will wash at the incoming water temp. It should not be showing green
If this is not the case, then the heater has probably failed.
To access the heater, you need to remove the top cover, remove the soap dispenser drawer, and undo the 4 screws securing the console panel to the top of the washer.
Pull off the timer knob, noting the position of it, and slide the console panel to the right, support it with something.
Remove wire cllip holding door seal to front of panel, and pull off the seal at the front.
Undo the screws securing the front panel at the top.
Undo 3 screws at bottom of front panel.
Lift front panel clear,and stand it at the right of washer, be careful of the wires still attached to the door lock.
At the bottom, in the center, you should find a black cover, remove that, and you will see the heater element.
You eally need a meter to test it for continuity, and or an earth fault.
Replace if faulty.
Please leave a fixya rating for my suggeted solution.
Thankyou.
Feb 09, 2009 | Creda W100FW Front Load Washer
Creda 1200 washing machine
make sure that your outlet pipe is at least 24 inches of the floor so you will not get dish water running back in the machine and give machine a quick wash using a good bleach hope this is usefull
Apr 28, 2008 | Creda W120VW Front Load Washer
Problems with creda washing machine
try your carbon brushes and drop your sump ie the pipe that connects to the pump on the inside of the machine and goes to the bottom of the drum this is the sump that sometimes blocks or may be a weak pump but try the other 2 options first good luck dont forget to unplug
Apr 14, 2008 | Creda W120VW Front Load Washer
Creda 1000 simplicity washing machine
try
www.theservicecentre.co.uk
creda and hotpoint website
good luck and rate me
Feb 17, 2008 | Creda W100FW Front Load Washer
I have a creda simplicity 1000 front loader washer.
Maybe the pipes are not connected to the heater on the wall. You could heat your water in the machine, if there is a provision; most machines have it.
Dec 01, 2007 | Creda W100FW Front Load Washer
Hotpoint WMA30 Front Load Washer Logo
88 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
