Question about Samsung SyncMaster 920WM LCD Monitor
I have problem with lcd monitor where the calor changed to green stain , as if you see monitor covered by screen sheiled or screen protector , the problem started on and off automatically then sustained and not resolved i tried to reset color and brightness but didn;t work i see the color of faces green their lips green i am not sure if problem from monitor or cpu how to know and how to fix it up
  • 26 Answers
Monitor is bad happend to me . new lcd fixed it
Posted on Oct 07, 2009
It is 7x3cm big, and its like dark green with bright green lines. I can see underneath it my screen, but only if i look deep.
if you can hooked up with other monitor just to ensure if the problem is only with in the monitor. after you replaced with other monitor then the display is clear or good picture, that was mean the only problem is the monitor. if the upper portion is black screen or the picture not so clear the cause is busted screen back light. to see the back light you will need to remove the back cover of the monitor. then the back light is a thin cold cathode flourescent tube, it was covered with a metal shield cover protection attached at the upper portion of the screen panel display.
Nov 08, 2012 | Samsung SyncMaster 913V 19" Flat Panel LCD...
I have my LG LCD flat screen TV, accidentally i bottle of Soda burst on the screen, i wipe it a dried it using a dry cloth, the next morning i have this black spots on my screen, please help
If you are sure its not a stain. then its a dead pixel on your monitor.. sooner or later it will spread out. To be sure if its a dead pixel, run your monitor in different colors, black screen, green, red and blue.. If the spots stays then its dead pixel.. You will be replacing the lcd when time comes that it spreads out.
May 18, 2010 | Televison & Video
E153PFc Dell monitor: cannot change resolution
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating red/green/blue/white dialog box should appear on screen against a black background. What appears?
Jul 17, 2009 | Dell E153FPc 15" TFT LCD Flat Panel...
I have water stains on my monitor! How do i fix it.
First off, NEVER USE WATER OR WINDEX OR ANY NORMAL HOUSEHOLD CLEANERS TO CLEAN ANY LCD DISPLAY. You need a special cleaner made specifically for those. Just cleaning it with the special cleaner will solve the problem if the water stains are on the outside of the monitor's screen. If the stains are inside, unfortunetly there is not much to do except bring it to your local technician and hope he can fix it. If he cannot, try to get it replaced under warranty or buy a new one.
Jul 07, 2009 | HP vs15 15"LCD Flat Panel Monitor
My Hanns-G hw191d monitor quit coming on. The green light at the side is on, indicating that it is receiving signal from the computer, but nothing displays on the screen. Is there a fix, or should I just...
First, flip the switch for your power surge protector, to see if that resolves. Then, test the monitor on another computer and see if it works. If the monitor still doesn't work, look for another one. Hope that helps.
Jul 06, 2009 | Hannspree HW191D LCD Monitor
Dell E228WFP two months out of warranty -monitor on and off
if your purchase just the monitor on 2/28/200, normally dell gives 3 years warranty for the monitor If purchased Separately.
OK.. try doing this call Dell.. 18004563355.. JUST give them the serial number of the monitor ONLY they'll check it out then if your lucky they'll send you a replacement.
Apr 23, 2009 | Dell E228WFP LCD Monitor
Dell E173FPc monitor. Screen is black, power button color cycles
First, verify the monitor is functional.
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective.
What are the results please?
Feb 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell monitor problem
Disconnect and reconnect both ends of the video cable (while the computer and monitor are both off). Also disconnect and reconnect the power cable. Is the power cable plugged into the same surge protector as the computer? And also try a different outlet on the surge protector for the monitor.
Jul 22, 2008 | Dell E153FP 15" LCD Monitor
Stains on the LCD monitor of Permanent marker
you could try mean green or totally awesome gotta love dollar tree. but be careful if you press too hard you could crack the screen or cause a pooling effect that may or may not go away. Oh or rubbing alc. last resort use liquid lighter fluid on a cloth.
May 22, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
LG L1930B 19" LCD Monitor Problem... HELP
When an LCD Monitor starts to respond like this it is due to one of three reasons a power supply is not generating enough power to properly power the LCD or the LCD's backlight is beginning to burnout, and last the inverter is bad. These things all can be replaced, but it is not worth the cost! Easier and cheaper to buy a new one!
Nov 25, 2007 | LG L1930B 19" LCD Monitor
Samsung SyncMaster 920WM LCD Monitor Logo
154 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
